What you defined above is not a sequence but a property.
sequence: A linear sequence is a finite list of SystemVerilog Boolean expressions in a linear order of increasing time. The linear sequence is said to match along a finite interval of consecutive clock ticks provided the first Boolean expression evaluates to true at the first clock tick, the second Boolean expression evaluates to true at the second clock tick, and so forth, up to and including the last Boolean expression evaluating to true at the last clock tick. A single Boolean expression is an example of a simple linear sequence, and it matches at a single clock tick provided the Boolean expression evaluates to true at that clock tick. More complex sequential behaviors are described by SystemVerilog sequences. A sequence always evaluates to true or false at its end point; thus if a sequence has a match, that match is true. A sequence is multi-threaded if it includes any of the following operators: and, intersect, or, range delay, consecutive range repetition, non-consecutive repetition (i.e., [=] operator. A sequence that is interpreted as a property is never vacuous.
What are your goals? Below are examples of usage, code simulates.
module test_if_st;
bit clk, a, b, c, d, cond1, cond2;
ap_test: assert property(@(posedge clk)
if(a) b ##1 c
else if(b) c ##2 d);
ap_1: assert property(@(posedge clk)
$rose(cond1) |-> if(a) b ##1 c );
// don't forget the $rose or $fell in the antecedents
// they are needed in most cases
ap_2: assert property(@(posedge clk)
cond2 |-> if(b) c ##2 d);
ap_3: assert property(@(posedge clk)
cond1 |-> if(a) b ##1 c
initial forever #5 clk = ! clk;
repeat(50) begin
@(posedge clk);
if (!randomize(a, b, c,d)) $error();
The syntax you used specified a sequence with the sequence … endsequence
The property syntax is property … endproperty
A property uses sequences and properties.
A sequence can be used as a property wherever a property is used.
Because your expressions contain property operators. Implication (if/else, |->} can only be used in a property. Sequence operators (##N) can be used in a property, but not the other way around.
