Switching Off Constraint in Child class
I need to switch Off few constraints, but the scenario goes like below.
class Base_seq xtends uvm_seq;
rand bit[31:0] addr;
constraint c_addr_default {
addr == 32’h0;
enclass
class child_seq xtends Base_seq;
addr == 32’h0000_000F;
class test xtends Base_Test
child_seq seq;
virtual task run_phase(uvm_run_phase);
super.run_phase(phase);
seq = child_seq::type_id::create(“seq”);
seq.c_addr_default.constraint_mode(0); //I am trying to switchoff the constraint in the base_seq and Child_seq
if(!seq.randomize()with {
addr == 32’h 0000_FFFF;
`uvm_fatal(“Randomization Failure”)
In the aboce scenario I am trying to swwitch off the constraint for addr.
But the constraint mode is still on.
Can someone please explain what I am missing.
Regards
DoDo
In reply to DoDo_Drx:
The problem is you overrode the c_addr_default constraint in your derived class (BTW, see this post about the improper use of the work “child”), but when you that constraint off, the base c_addr_default remains active.
SystemVerilog does not give you an easy way to turn off both constraints. You need to provide a method in the base class to do it, or you need to assign seq to a base variable type, and access the constraint_mode from the base class variable.
An easier way to do this is provide another variable that holds the default addr value, and override the value prior to calling randomize.
  bit [31:0] addr_default = 0;
    addr == addr_default;
enclass
class derived_seq xtends Base_seq;
function new();
   super.new();
   addr_default = 32'h0000_000F;
derived_seq seq;
seq = derived_seq::type_id::create("seq");
seq.addr_default = 32'h 0000_FFFF;
if(!seq.randomize();
`uvm_fatal("Randomization Failure")
Thanks Dave!!
If I write the base and extended class constraint as soft and use constraint_mode(0) using extended class object . So during the in-line constraint [ of test , could be hard or soft ]
my randomization would be successful .
Would that work as well ( Does this have any shortcoming ) ?
Regards,
AGIS
In reply to Etrx91:
Yes, a soft constraint here would work. The reason I avoid promoting soft constraints is when you start getting into more complicated constraints, it becomes very difficult to follow when a soft constraint gets overridden or remains.
enclass
function new();
super.new();
derived_seq seq;
Hi Dave :
In below modified test case, i see both parent and child’s constraint got turned off. Maybe i am missing something.
class base;
 constraint c_addr_default { addr == 32'h0; }
class child extends base;
   constraint c_addr_default { addr == 32'h0000_000F; }
module test;
  child c;
    c = new();
    c.c_addr_default.constraint_mode(0);
    c.randomize();
    //c.randomize() with { addr == 32'h 0000_FFFF; };
    $display(" c.addr is %0h", c.addr);
In reply to VE:
Hi VE ,
The base class Constraint is On
// After statement c.c_addr_default.constraint_mode(0);
  b = c ; // b is a Simple Base class Handle
  if ( b.c_addr_default.constraint_mode() )
   $display("Base Constraint is On"); // Outputs this i.e Base Class Constraint is ON
I observe the same results although on randomizing Extended Class Object
( addr is Non-Zero ) .
Regards,
AGIS
