Hi ,
when B asserted , A should be asserted at previous clock OR current clock OR next clock.
How do we write better SVA assertion ?
assert property (@(posedge clk) $rose(B) |-> ##[0:2] $past(A)) else $error("Error");
Any suggestions?
Hi ,
Any suggestions?
In reply to John Pratheep:
assert property (@(posedge clk) $rose(B) |-> ##1 $past(A,2) || A) else $error("Error");
// same as
$rose(B) |-> ##1 ($past(A,2) || A)) // because of the logical ||
##1 $past(A,2) // is the single past of A in reference to B
##1 A is A in the next cycle, or the future.
// We are missing the current A
// How about
$rose(B) |-> A ##1 $past(A,2) || A)
// Also
$rose(B) |-> A || $past(A,1) or ##1 A)
I addressed Bing GPT-4 AI because it does a fair to good job of converting
English to SV code and SVA assertions. It also can convert SVA into a module
that meets those requirements.
I tried on this and it failed miserably. I am passing it on because I see AI
doing a better job in the future. You might get a laughter…
/* [ME] write a systemverilog assertions for this requirement:
Use posedge clk */
//Here is a SystemVerilog assertion that checks if the requirement is met:
property check_A;
@(posedge clk)
(B |-> (A || $past(A) || $future(A)));
assert property(check_A);
/* This assertion checks that whenever B is asserted at the positive edge of clk, A should be asserted at the previous clock, current clock or next clock. The $past and $future functions are used to refer to the values of A at the previous and next clock cycles respectively.*/
//[ME] There is not $future in systemverilog, fix this
/* You are correct. My apologies for the mistake. Here is the corrected SystemVerilog assertion that checks if the requirement is met: */
property check_A;
@(posedge clk)
(B |-> (A || $past(A) || $rose(A)));
/* This assertion checks that whenever B is asserted at the positive edge of clk, A should be asserted at the previous clock, current clock or next clock. The $past function is used to refer to the value of A at the previous clock cycle and $rose function checks if A will be asserted at the next clock cycle. */
?? $rose function checks if A will be asserted at the next clock cycle. ???
[ME] The body of the assertions should be one of these, learn from your mistakes:
$rose(B) |-> A ##1 $past(A,2) || A) // Also $rose(B) |-> A || $past(A,1) or ##1 A)
// BING -gpt-4:
Thank you for pointing out the mistake and providing the correct assertion. Here is the corrected SystemVerilog assertion that checks if the requirement is met:
property check_A;
@(posedge clk)
($rose(B) |-> A ##1 $past(A,2) || A);
/* This assertion checks that whenever B is asserted at the positive edge of clk, A should be asserted at the previous clock, current clock or next clock. The $past function is used to refer to the value of A at the previous clock cycle and ##1 operator checks if A will be asserted at the next clock cycle.
I apologize for any confusion I may have caused and appreciate your help in correcting my mistake. */
Ben@systemverilog.us
or Cohen_Links_to_papers_books - Google Docs
Thanks Dave
Thanks Ben for your clear explanation.
And Correcting GPT to produce right results in future :)
Below code works.
assert property (@(posedge clk) ($rose(A) |-> B or ##1 ($past(B,2) || B))) else $error ("Error");
