SVA: Sampling clk on consequent
I need to code following assertion, which states.
(Signal A is synchronous to Clk1. )
"CLK1 must be available for 2 clocks, once Signal A is de-asserted (0->1));
I want to code concurrent assertion for the above statement.
Will this work?
property clk_stable;
@(posedge clk1)
$fell(A) |-> ($rose(clk1)==1) [*2];
end property
Please let me know the correct way of doing this kind of SVA when Sampling clk need to be used in antecedent of the property.
@(posedge clk1) $fell(A) |-> ($rose(clk1)==1) [*2];
The “($rose(clk1)” clocked with @(posedge clk1 means that @(posedge clk1) you are sampling the signal clk1 one delta time (i.e., just before) the posedge clk1. At that time, the sampling of clk1 has a value of ZERO!!! Also, you are using |-> (i.e., in the same cycle), thus the assertion will fail at $fell(A).
You could however do the following:
ap_2cloks: assert property(@(posedge clk1) $fell(A) |=> strong(1[*2]);
The strong is necessary to qualify an assertion as a failure if the consequent never terminates at the end of simulation.
Thanks Ben for the info.
For my understanding, I understood the first part:
The following :
strong(1[*2])
Does this ensure clk1 is available for atleast 2 clocks when A transition from 1->0.
The assertion to be coded was “When A transition from 1->0, clk1 must be present for atleast 2 more clks”
Note: Signal A becomes 1 and 0 multiple times in the simulation. It is synchronous to clk1.
Also any pointers for understanding strong keyword.
In reply to shekhil52:
The “assert property(@(posedge clk1) $fell(A) |=> strong(1[*2]);”
says "For every attempt. at (posedge clk1, if there is a $fell(A) then there must be 2 next posedge clk1.
If the simulation ends and that last attempt succeeded and started, but there were no 2 more posedge clk1, then that assertion fails because it is strong. Without the strong, it is ignored. Note that for each successful attempt, the assertion terminates and succeeds when there are 2 more posedge clk1. You can have Signal A becomes 1 and 0 multiple times in the simulation, and for each one, a new assertion thread is initiated.
Does that make sense?
  • SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
Perhaps there is a misunderstanding in “CLK1 must be available for 2 clocks”. I have never seen a requirement written like that. Usually it is “must be at least 2 clocks before something else is allowed to happen”. What is that something else?
Agreed,it is odd. I took as some sort of ending condition with an enable for 2 more clocks. Weird, though! The author’s initial solution makes a good quizz about what’s wrong with the property.
Ben:
Thanks for the details! This helps.
Dave_59:
There can be cases in which “A” is a control signal which essentially could be a datavalid which could be consumed by an external module or block which buffer data and do some stuff with that.
Now since clk1 is the clk used to sample the data inside the external module, there might be requirement from the external module to provide the clk1 for at least some more clk(here its 2 clk1 clocks) for the external module to process the data/end the pipeline logic. This could be the scenario from which the property comes “A(control signal) when transition from 1->0 ensure at least 2 clk1 clocks are available”.
-Shekhil
Given the requirements you have, a better solution that counts the number of successes and displays failures would be to use something as shown below where the lack of 2 clocks is flagged immediately because there is another path that fails if no 2 clocks. The concurrent assertions I wrote depends on the clocks, and the assertion would pass if, for instance, you get a fell(a) and no clocks for 10 seconds, and then 2 clocks.
module test;
  bit a;
  bit clk; // continuous clock
  bit io_clk; // clock from io, in reponse to $fell(a)
  event e;
  always @(posedge clk)
      if($fell(a)) -> e;
  always begin
      wait (e);
            repeat(2) @ (posedge io_clk);
            ap_pass2clocks: assert(1); // tool keeps count of successes
            repeat(3) @ (posedge clk);
            ap_no2clocks: assert(0) else $display("did not receive expected IO clocks");
      join_any
Ben Cohen systemverilog.us
Thanks Ben.
May be this also will work:
reg [1:0] count_2_clk;
always@(posedge clk1) begin
if(rst) begin
count_2_clk <=2’d0;
else if($fell(a)) begin
count_2_clk<=count_2_clk+1;
if(count_2_clk==2’d2)begin
count_2_clk<=2’d0;
assert property(@(posedge clk1) $fell(a) |-> (count_2_clk==2’d2));
This also should work i think. Any feedback?
And what if you don’t get the clk1 after ($fell(a))?
That is why I suggested a continuous clk1 and an IO_clk1, the one that you are testing.
Ben
Oh ok! Yes my code won’t work then. We need a continuous clock to check, I get it now. Thanks Ben :)
