SVA: Sampling clk on consequent
@(posedge clk1) $fell(A) |-> ($rose(clk1)==1) [*2];
The “($rose(clk1)” clocked with @(posedge clk1 means that @(posedge clk1) you are sampling the signal clk1 one delta time (i.e., just before) the posedge clk1. At that time, the sampling of clk1 has a value of ZERO!!! Also, you are using |-> (i.e., in the same cycle), thus the assertion will fail at $fell(A).
You could however do the following:
ap_2cloks: assert property(@(posedge clk1) $fell(A) |=> strong(1[*2]);
The strong is necessary to qualify an assertion as a failure if the consequent never terminates at the end of simulation.
