It is my DUT which initiates Write and Read. The above assertion fails as my DUT might initiate multiple writes to the same address continuously with incremental data (say usually across 2 or 3 clock cycles).But the read for a given address will always be for 1 clock
As a result, 2 or 3 instance of same assertion gets spawned for every write cycle for the same address. Only the assertion-instance for the last write cycle (where the complete stable data is available) passes. The previous assertion-instances fails.
How to filter the last write on the LHS? I’m looking of something like/equivalent to ‘last_match’.
Thanks in advance.
Note: I cannot have an external logic to derive the LastWrEn, LastWrAddr as this would consume atleast 1 WrClk cycle. The ultimate objective of the assertion is to detect read/write overlap. By consuming 1 WrClk cycle the assertion would miss to detect such scenarios.
Below code is almost same as having an external logic having 1 WrClk delay.
In reply to run2prem:
Your last solution looks OK. I would change
first_match (##[0:$] (RdEn && (RdAddr == Addr))) to
(RdEn && (RdAddr == Addr)[->1] // easier to read.
You definitely need something that determines a LastWrEn, LastWrAddr. I Thought of using straight SystemVerilog code with tasks, as described in my paper SVA Alternative for Complex Assertions available at https://verificationacademy.com/news/verification-horizons-march-2018-issue
Pseudocode would look something like
always @(posedge WrClk)
// local variables for last write
if (WrEn, Addr = WrAddr && lastwrite)
fork test_task();
join_none
task automatic test_task();
write loop to do the check and report error
// This approach gives you all the flexibility and features of SystemVerilog
Thanks for the quick suggestion. If I understand correctly, you suggest to use SV rather than SVA for this particular check. Yes, there is no handy ‘last_match’ construct available.
But for now, I’ve taken the below approach.
The WrAddr is my DUT’s output port.
The driver of this port would be somewhere deep inside the RTL.
We shall use a signal which is one flop-stage before the actual driver (say WrAddr_pre). Do port mapping in the assertion module using HDL path of this signal.
Luckily, my DUT has a clear register stage for this signal.
That pure SV approach basically computes the antecedent and then fires automatic tasks for the consequent as threads. It overcomes some of the issues with local variables and provides more flexibility since you use the full power of SV. Typical code would look like:
Understanding the equivalent mechanics and limitations of SVA can help create a better SVA model.
Your code looks like it has the correct approach, but I have an issue with its correctness.
You are looking for the last write cycle. Assuming that that you load the register with 2, 3 or 4 consecutive writes, and WrAddr is an active ONE, then the last write would occur when
$fell(WrAddr_pre)&& WrAddr rather than your WrAddr != WrAddr_pre.
Test your assertions with a simple testbench. I use the following as a test template, then fill-in the details. That template is stored in an Autotext and Text Autocompletion in any application using the application available at no cost at https://www.phraseexpress.com/
timeunit 1ns; timeprecision 100ps;
bit clk, a, b;
initial forever #10 clk=!clk;
$timeformat(-9, 1, "ns", 8);
$display("%t", $realtime);
always @(posedge clk) begin
bit va, vb;
repeat(200) begin
@(posedge clk);
if (!randomize(va, vb) with
{ va dist {1'b1:=1, 1'b0:=3};
vb dist {1'b1:=1, 1'b0:=2};
a <= va;
b <= vb;
$stop;
Thanks. Will definitely go through your paper in detail.
I’m not clear with your assumptions here. WrAddr & WrAddr_pre are 7-bit wide. $fell(WrAddr_pre)??? Not sure what you mean by ‘WrAddr’ is an active ONE???.
WrEn is an active high signal in my case.
The idea behind (WrAddr != WrAddr_pre):
WrAddr_pre will be 1 WrClk ahead w.r.t WrAddr.
Last cycle of current address for WrAddr will be nothing but the first cycle of WrAddr_pre for a new address.
Its the last cycle of WrAddr when WrAddr and WrAddr_pre will not be equal.
first_match(## [0:$] b ) is same as
first_match(##0 b or ##1 b or ##2 b or ...), basically the first occurence of b
b[->1] is equivalent to: !b[*0:$] ##1 b, same as
(!b[*0] ##1 b)or (!b[*1] ##1 b)or (!b[*2] ##1 b) or ...
I misunderstood the requirements as I interpreted the WrAddr as a write enable
In any case, the analysis as to how you detect a last write is something you need to determine, and I do not want to get into your specific design. My goal is to help you with the tools. Your verification environment can buffer as many signals as needed to determine that last write and then to the check at a later time. The point of verification is to detect correctness in the design; there is no requirements that the detection be exactly at the cycle the error occurred, it could be a bit latler.
