Is it legal to write something like below - I didn’t find anything against this in LRM
works on major 3 simulators though.
want to check, if there was a rising edge on a particular signal 3 clocks early
There are cases where one may want to assert that if there is an effect it is because of a cause (or one of possible causes).
For example, one would assert that you only get gnt if there was a req.
You don’t want to see a spurious gnt.
One could use the $past, but the number of cycles of the past has to be static, no range. For that case of a range, asolution is to use support logic that latches (store) the event of a req and resets it with the gnt.
You can then assert something like
