SVA for Invalid FSM state transition
Hi Forum,
The intention of my SVA is to flag an error when the state machine transitions from S1 → S3 → S6.
The assertion should also consider cases that a state is stable across multiple clocks
Here is my attempt : edalink
‘ap2’ uses the same clocking event as fsm and throws an error on next clock of the NBA assignment of S6 ( since pre-poned values are used in concurrent assertions ) whereas ‘ap1’ uses SV regions to throw an error on same clock that the NBA assignment occurs.
I was trying to compare the advantages and disadvantages of both solution.
Here are a few advantages I have noted of ‘ap1’ over ‘ap2’
  1. If there is no posedge of clock after T:65 , ‘ap2’ would never trigger the fail action block whereas ‘ap1’ would trigger it.
  2. As the clocking event for ‘ap1’ is whenever ‘ps’ state changes, I believe it is more simulation efficient than ‘ap2’
I have a few questions for the forum moderators
[Q1] Are there any advantages of ‘ap2’ over ‘ap1’ ?
[Q2] Are there any disadvantages of ‘ap1’ ?
[Q3] Are both solution acceptable ?
[Q4] Are the solution an example of a valid use case of using multiple non-overlapping implication operators ? For other state transitions there would be a vacuous pass due to multiple |=> which I believe is fine as per intention
  1. Use the system clock for the assertion.
  2. I would NOT use a signal as a clock; it is bad practice. That style may not be supported by FV.
  3. In general, I do not like these of multiple implication operators.
  4. ( ps == S1 ) |=> ( ps != S1 )[->1] ##0( ps == S3 )
    DO you want the $rose(ps==S1)?
    Why the ( ps != S1 )[->1] ?
    Why not using ( ps == S3 [->1])?
  5. I don’t like the not( ( ps != S3 )[->1] ##0 (ps == S6) );
    because it does not express what the property should do.
    How about something like:
property prop_better;
    @(posedge clk)  // Clocking event on each posedge of clock
    ( ps == S1 ) |=> ( ps == S3 )[->1] ##1
    (ps != S3 && ps!=S6)[->1] intersect  (ps != S6)[*1:$] ;
  1. Your TB should use nonblocking assignments as a good practice rule.
  2. Aside from directed tests, you should consider randomization.
  3. I strongly suggest that you read my reply on “Getting started with verification with SystemVerilog”
    https://rb.gy/f3zhh
    file is also attached.
    Ben@systemverilog.us
    https://systemveri
roadmaptosva.pdf (172.0 KB)
Hi Ben,
Please find attached comments
If there is no clocking event after T:65 i.e on the posedge that ‘ns’ is assigned S6 there would be no error. Any way to bypass this limitation ?
DO you want the $rose(ps==S1) ?
Yes, this would be better to restrict the attempts
Assume the sampled states on each posedge of clock are S1 , S1 , S1 , S3 , S3 , S3 , S3 , S6
So using ( ps != S1 ][->1] it waits for state to transition from S1 to non-S1 state thereby ignoring the same state S1 across multiple clocks.
Why not using ( ps == S3 )[->1])?
Using this I would observe assertion failure if the sampled states were S1 , S1 , S2 , S3 , S3 , S3 , S6.
Via ( ps != S1 )[->1] ## 0( ps == S3 ) , ‘ap2’ checks that after S1 the next non-S1 state is S3. So for above state transition there would be a vacuous pass due to transition to S2.
I don’t like the not( ( ps != S3 )[->1] ## 0 (ps == S6) );
Go-to repetition would wait for the non-S3 state after S3. If the non-S3 state is S6 the assertion fails as per intention
A few questions of mine ::
An alternative I tried edalink2 .
(a) Would like to hear your thoughts on it
(b) This particular question was the 1st case that I thought could use multiple non-overlapping implication.
If the sample states over posedge of clock is S1 , S1 , S2 there would be a vacuous pass due to 2nd |=>
​[Ben_Q] Why the ( ps != S1 )[->1] ?
​[UR_A] Assume the sampled states on each posedge of clock are S1 , S1 , S1 , S3 , S3 , S3 , S3 , S6
So using ​( ps != S1 ][->1] it ​state thereby ​ignoring the same state S1 across multiple clocks.
​[Ben_A] ( ps != S1 ][->1]​ is same as !(ps!=S1)[*0:$] ##1 ps!=S1
​YES on “waits for state to transition from S1 to non-S1​”.
​NO on “ignoring the same state S1 across multiple clocks.​”
​[Ben_Q] Why not using ( ps == S3 )[->1])?
​[UR_A] Using this I would observe assertion failure if the sampled states were S1 , S1 , S2 , S3 , S3 , S3 , S6.
​[Ben_A] I generally do not recommend the verification of FSM with assertions between states. FSMs should be verified thru assertions of the requirements. For example,
​$rose(tlight==YELLOW) |=> tlight==YELLOW[*1:4] ##1 tlight == RED;
​[Ben_Q] I don’t like the not( ( ps != S3 )[->1] ## 0 (ps == S6) );
​[UR_A] Go-to repetition would wait for the non-S3 state after S3. If the non-S3 state is S6 the assertion fails as per intention
​[Ben_A] As a matter of preference, I prefer to write assertions that define what SHOULD be true instead of what should NOT be true. I sometimes use the “not” operator, but not too often.
​[UR_Q] A few questions of mine ::In general, I do not like these of multiple implication operators.
​[Ben_A] With nultiple implication operators you have multiple cases of vacuity; it makes the assertion more complex IMHO.
​I prefer multiple simple assertions over complex ones.
​[Ben_A] You are referring to:
​( ps == S1 ) |=> ( ps != S1 )[->1] ##0( ps == S3 ) |=> not( ( ps != S3 )[->1] ##0 (ps == S6) );
if (ps==S1) is false, the property is vacuous.
It would also be vacuous if under the dame condition you wrote:
( ps == S1 ) ##1 ( ps != S1 )[->1] ##0( ps == S3 ) |=> …
Thus, the first “|=>” does nothing for you, just makes it harder to read.
The antecedent is a precondition to test the consequent. Mutiple ones makes it more complex IMHO
I tried with a different approach.
(current_state == STATE_1)[*1:$] ##1 (current_state == STATE_2)[*1:$] |=> (current_state != STATE_3)[*1:$]).
Can this still cover all possible scenarios?
(current_state == S1)[*1:$] ##1 (current_state == S2)[*1:$] |=> (current_state != S3)[*1:$]).
/*From a requirement point of view, this says if S1 is eventually true and if S1 is immediately followed with S2, then this is followed by !S3 forever. Example: */
S1 S1 S1 S2 !S3  // pass
S1 S1 S2 S3 // FAIL
// Can rewrite your code as
(current_state == S1) ##1 (current_state == S2) |=> (current_state != S3)).
// (current_state == S1)[*1:$] ##1 (current_state == S2)[*1:$]
// the sequence S1[*2] ##1 S2 makes the antecedent vacuous
//  For nonvacuity you only need S1 followed by S2
Hello Ben,
I understood. But can you let me know why the below would logically fail? (although constant checking of current_state == S1 is not required)
(current_state == STATE_1)[*1:$] ##1 (current_state == STATE_2) => (current_state != STATE_3))
Also, I was not able to understand the below lines:
 //understood. But can you let me know why the below would logically fail?
 //(although constant checking of current_state == S1 is not required)
//Consider the threads:
S1[*1] ##1 S2  // S1 S2 thread makes the assertion nonvacuous
// If you have the sequence S1 S2
//   then the other threads S1[*2], S1[*3], S1[*n] are all not a match
//   (S1 S2 says that you do not have S1[*2] and all the others.
// S1[*4] ##1 S2 => !S3 // S1 S1 S1 S1 S2 S3 is a fail, expecting !S3
// Again, you do not need the [*1:$] because the nonvacuous antecedent is the last S1 with S2
// [You] Also, I was not able to understand the below lines:
// [Ben] I did not convey the correct message, my apologies.
S1[*2] ##1 S2 is same as
S1 S1 S2// thus if the input is S1 S2 the antecedent is vacuous.
// If the sequence is
S1 S1 S2 // then you have nonvacuity
I understood now. Thank you for the detailed explanation.
More thoughts:
Q: How to simplify this property
	 (state== S1)[*1:$] ##1 (state== S2)[*1:$]  => (state= S3)[*1:$]
  A: (state== S1) ##1 (state== S2)[*1:$] |=> (state= S3))
  Explanation: The antecedent has these threads:
     (state== S1)[*1] ##1 (state== S2)[*1] or
	 (state== S1)[*2] ##1 (state== S2)[*1] or
     (state== S1)[*n] ##1 (state== S2)[*n];
	For the property to succeed, we need an attempt with state== S1
	followed by state== S2 repeated n times until state== S3.
	Thus, with 	let T1=state==S1;  let T2=state==S2; let T3=state==S3;
	the following state value will make the property true:
	attempt number
	1  2  3  4  5  6  7
	T1 T1 T1 T2 T2 T2 T3  // with the sequence attempted at attempt 3 being considered.     // Attempts 1, 2, 4, 5, 6, 7 make the property vacuous
UPDATED
SVA: Q: How to simplify this property
(state== S1)[*1:] ##1 (state== S2)[*1:] => (state= S3)[*1:$]
A: (state== S1) |-> ##1 (state== S2)[*1:$] ##1 (state= S3))
Explanation: For the property to succeed, we need an attempt with state== S1
For an assertion to be successful, two requirements must be met:
  1. There must be no failure in the search of a matched antecedent with a consequent.
  2. All threads of the antecedent and consequent must be successful. There are two types of successes: vacuous and nonvacuous.
SVA: Emulating “until” with a sequence:
This question came up from a user and my original response in https://lnkd.in/gxmA5gkm
/* Requirements:
 If st==S1 and if it is then immediately followed by st==S2 for 1 or more cycles then S3 will follow the last S2. */
 // ILLEGAL Solution
 ap_illegal: assert property(@(posedge clk)
 $rose(st== S1) ##1 ((st== S2) until !(st==S2)) |-> (st==S3));
 // Illegal because the until is a property operator, needs a sequence for an antecedent
 // Emulating the "until" with a sequence
 ap_legal: assert property(@(posedge clk)
 $rose(st== S1) ##1 ((st== S2)[*1:$] ##1 1 intersect (st!=S2)[->1]) |-> (st==S3)) p2++; else f2++;
Notice the sequence that has a ##1 after the repeat and the
The intersect constraints the sequence to one choice.
If that sequence matches, then we are in the cycle following the last S2, and thus we need the |-> operator.
Test code
