SVA : Disable assertion to bypass transition from x --> 0/1
HI,
I have a situation where there is a variable transition from x to 1/0. i.e A transition of value
from X to 0 is not a rising edge and hence the sequence fails.
I want to filter from triggering the assertion.
I want to know how to detect and filter the assertion not to trigger.
-Regards,
-Raja.
In reply to sraja:
Have you tried the $isunknown ( expression )?
$isunknown (data);
// true if any bit of the vector is X or Z
// same as $countbits(data,‘X,‘Z)
logic a=X;
logic b;
!$isunknown(a) && rose(a) |-> b;
  • SystemVerilog Assertions Handbook 4th Edition, 2016 ISBN 978-1518681448
Hi Ben,
Yes, I used the same $isunknown(data).I could able to disable the assertion when clock and rst goes from x to initial value.
Here is the picture
Imgur
Thanks for the solution.
I would like to know the transition from X->0 or X->1 and detect it.how can i do that.is there any construct in SVA. Only for the purpose to detect X → 0/1.
-Regards,
-Raja.
In reply to sraja:
You can use a function or just the “===” comparator
logic clk=0, a=1'bX;
	initial forever #10 clk=!clk;
    	initial #203 a=0;
	ap_1: assert property(##1 $past(a) === 1'bX) $display ("a=X");
My question though, why are you not using type bit, or initialize the objects of type logic to 0 or something that is not an X. Real hardware does initialize to something, 0 or 1, but not an X.
HI Ben,
Nice Idea!!!
I can do it using bit data type as it is two state type.
I cannot use logic and assign initial value.I am probing rtl signals and assigning to reg data type in the assertion modules.
something like this…
assign sec_clk = `RPITP.opidatacluster0.opistrbmodule.opistrbpgunit.opipcspgstrblane.rxclock_top_dig.rxclock_dll_top1.dll_dig.rxclock_dll_acc.ck_acc;
I use this sec_clk variable in the assertion.
so i think cannot initialize some value.
Thanks you.
-Regards,
-Raja.
