If you insist on writing the code in SVA, then consider the following
// SVA SOLUTION THAT WILL NOT WORK !!!!
property WILL_NOT_WORK_countab;
int va=0, vb=0;
go |-> ##[1:$] (a || b, va=va+a, vb=vb+b) ##0 (done, dostats(va, vb));
ap_LOOKS_LIKE_IT_WILL_WORK_BUT_DOES_NOT_WORK: assert property( p_countab);
The property shown below fails to work because in SVA, if the sequence makes assignments to local variables, then each of the sequence involved in the ORing carries its own individual and separate copy of the local variables.
the (##[1:$] seq) is same as (##1 seq or ##2 seq or … ##n seq)
The following will work though because the property calls a task as a match item, and pass whatever values are needed. Thus,
task do_calc(int va, vb, bit go, done);
static int cta;
static int ctb;
if(go) begin cta=0; ctb=0; end
if(done) begin
$display("t=%t, calc_cta=%d, calc_ctb=%d, stats=", $time, cta, ctb, 100*cta/ctb);
if(a) cta=cta+1'b1;
if(b) ctb=ctb+1'b1;
property p_countab_ok;
int va=0, vb=0;
(go, do_calc(va, vb, go, done)) |->
(##[1:$] (a || b, do_calc(va, vb, go, done)) ##0 done) or
(done[->1], do_calc(0, 0, 0, done));
ap_countab_ok: assert property(p_countab_ok);
Simulation file is at http://SystemVerilog.us/fv/countpulses.sv
sim results
# t= 650, ctab_cta= 7, ctab_ctb= 6, stats= 116
# t= 650, calc_cta= 7, calc_ctb= 6, stats= 116
# t= 1250, ctab_cta= 12, ctab_ctb= 9, stats= 133
# t= 1250, calc_cta= 12, calc_ctb= 9, stats= 133
# t= 1850, ctab_cta= 12, ctab_ctb= 8, stats= 150
# t= 1850, calc_cta= 12, calc_ctb= 8, stats= 150
