Hi everyone,
I’m struggling to figure out how to check a signal value doesn’t change mid-cycle via SVA.
Could I use $stable for this? - I thought $stable could only be used to check signal stability across multiple clock cycles, but not on the same clock cycle
To give a bit more perspective, let’s say I have a clock (clk), a signal (signal_a), which must not change across an entire clock cycle, and signal_a is driven on the neg-edge.
I tried using 2 properties, one with $rose, another one with $fell
property negedge_rose_signal (disable_condition, signal_a));
@(negedge clk ) disable iff (disable_condition)
$rose(signal_a) |-> @(posedge clk) signal_a==1;
property negedge_fell_signal (disable_condition, signal_a);
$fell(signal_a) |-> @(posedge clk) signal_a==0;
//Instantiating
rose_p: assert property ( negedge_rose_signal (enable, signal) );
fell_p: assert property ( negedge_fell_signal (enable, signal) );
The above is not working. Does this fall within the multi clock SVA category?
I have attached a screenshot which depicts a clock signal and a signal which doesn’t remain stable across the entire clock cycle, which is the situation I’m trying to have a check for.
Thanks in advance
I unstaood your question to mean that if (b_stable) then sig “a”
must not toggle in that cycle.
THIS SOLUTION IS INCORRECT
BECAUSE ANY FIRED TASK CAN SET THE
change TO 1
Edit code - EDA Playground // code
EPWave Waveform Viewer // wave
module top; // BAD SOLUTION
`include "uvm_macros.svh" import uvm_pkg::*;
bit clk, a, b_stable, changed;
int p1, f1;
initial forever #3 clk = !clk;
always @(posedge clk) begin
fork : FORK // DO NOT USE!!
int count;
begin changed=0; end
begin @(a) changed=1; end
join_none
ap_stable_a: assert property(
@(posedge clk ) // disable iff (disable_condition)
b_stable |-> ##1 changed==0) p1++; else f1++;
bit v;
$dumpfile("dump.vcd"); $dumpvars;
repeat (20) begin
@(posedge clk);
if (!randomize(v, b_stable) with {
v dist {1'b1 := 2, 1'b0 := 1};
b_stable dist {1'b1 := 4, 1'b0 := 2};
}) `uvm_error("MYERR", "This is a randomize error");
if(v) #1 a=!a;
$finish;
Ben@systemverilog.us
Above is a bad solution.
Need a different approach.
Hi Ben - thanks for your reply.
I just need to check that a signal driven on the negedge, does not change value during the entire clock cycle. The waveform screenshot I attached shows the data signal going low on the neg-edge of the clock, and coming back high on the pos-edge. I want the assertion to fire at that point.
I thought this was straightforward with direct assertion syntax, but so far I’ve not managed to write one successfully.
I’ve been able to successfully get the assertion to fire with glue logic.
// Data is driven on the neg-edge, and I want to check the data line
// does not change across a given clock cycle
logic neg_value, pos_value;
forever begin
@ (negedge n_enable); //Active low enable
// The data are driven on the negedge, so the first value of the
// pos_value will need to be updated on the first negedge
@ (negedge clk);
pos_value <= data_line;
//Latching values on pos/neg edges to then compare the assertion
always @(negedge clk or negedge n_rst) begin: neg_update
if(!n_rst)
neg_value <= 0;
else if(!n_enable) begin
neg_value <= data_line;
always @(posedge clk or negedge n_rst) begin: pos_update
if(!n_rst)
pos_value <= 0;
SAME_VALUE_CHECK_P: assert property (pos_value == neg_value);
The code above does what I want I think (I’ve seen the assertion fire when expected only). Can the above not be simplified into a multi-clock assertion such us:
property signal_change_check (data_line));
logic neg_edge_value;
@(negedge clk )
(1, neg_edge_value = data_line) |=> @(posedge clk) neg_edge_value == data_line;
I don’t understand why the assertion above doesn’t work. Is it required for multi-clock SVA checks for the clocks to have different frequency?
I’ve also tried swapping
For:
(1, neg_edge_value = data_line) |=> ##1 @(posedge clk) neg_edge_value == data_line;
I see the assertion failing differently, but still not what I want.
I don’t quite understand what you are trying to do and why.
- You have a signal “data” being driven in a nonblocking manner at negedge clk. Thus, @(negedge clk) data<=some_value;
- Data will change after the clock edge.
- You want to check that “data” is stable from the next posedge to the
next negedge. Why?
The following seems to work
Edit code - EDA Playground code
EPWave Waveform Viewer wave
//`include "uvm_macros.svh"
// import uvm_pkg::*;
bit clk;
bit[2:0] data, p1, f1, p2, f2;
// Am assuming that the data has a setup time,
// meaning that data cannot change in the exact time as negedge clk.
// I am also assuming that data is drivien in a nonblocking assignment
// i.e., @(negedge clk) data<= an_int_value;
task automatic t();
int v; bit fail, pass;
@(posedge clk) v=data;
wait(data != v); fail=1;
begin @(negedge clk) pass=1; end
join_any
am_data: assert(fail==0) p1++; else f1++;
endtask //automatic
always @(negedge clk) fork t(); join_none
property signal_change_check;
bit[2:0] v;
@(posedge clk )
(1, v= data) |=> @(negedge clk) v == data;
ap_signal_change_check: assert property(signal_change_check) p2++; else f2++;
bit[2:0] v; bit err;
repeat (20) begin
@(negedge clk);
if (!randomize(v, err));// `uvm_error("MYERR", "This is a randomize error");
if(err) begin
#1 data<=v;
@(posedge clk) #1 data<= v+1'b1;
else #1 data<=v;
$finish;
Hi Ben,
I wrote a property almost identical to the one you suggested in your last comment:
@(negedge clk )
However, the property was not working as expected as it was failing even when the signal on the negedge was the same as in the posedge.
I want to check the signal doesn’t change value mid-cycle, because the signal can be driven on the neg or pos-edge depending on configuration, and had a case in which the signal was wrongly toggling mid-cycle.
Hi Ben
Thanks for your response.
Can you explain what you’re trying to achieve by switching |=> to |->?
I tried it anyways, but the assertion fails identically as when I use |=>.
The LRM says in section 16.13.2 (Multiclocked properties):
The meaning of multiclocked nonoverlapping implication is similar to that of singly clocked nonoverlapping
implication. For example, if s0 and s1 are sequences with no clocking event, then in
@(posedge clk0) s0 |=> @(posedge clk1) s1
|=> synchronizes between posedge clk0 and posedge clk1. Starting at the point at which the implication
is being evaluated, for each match of s0 clocked by clk0, time is advanced from the end point of the match
to the nearest strictly future occurrence of posedge clk1, and from that point there must exist a match of
s1 clocked by clk1.
The following example shows a combination of differently clocked properties using both implication and
Boolean property operators:
@(posedge clk0) s0 |=> (@(posedge clk1) s1) and (@(posedge clk2) s2)
The multiclocked overlapping implication |-> has the following meaning: at the end of the antecedent the
nearest tick of the consequent clock is awaited. If the consequent clock happens at the end of the antecedent,
the consequent is started checking immediately. Otherwise, the meaning of the multiclocked overlapping implication is the same as the meaning of the multiclock nonoverlapping implication.
For this case, where the first event is on the neg-edge and the second on the pos-edge both overlapping and non-overlapping implication operators are correctly behaving in the same way.
So far I’ve only been successful at getting the check to work using concurrent assertions and some glue logic around sampling the values at the neg and pos edges.
This still feels like it can be check via SVA in a more simple manner though.
