SV Constraint :: Address must be aligned to the size of the transfer
Hi All,
If AxSize is ‘N’ then the address must be aligned to 2**N
Eg: For AxSize == 2 then address[1:0] == 0 i.e aligned to 4-byte
For AxSize == 3 then address[2:0] == 0 i.e aligned to 8-byte
Thus lower ‘AxSize’ bits are 0’s i.e Address[ (AxSize-1):0] == 0
   //  Declaration of address and axsize random variables
    rand  bit[11:0] axaddr;  // In reality Address Width is 32 bit i.e [31:0]
    randc bit[2:0] axsize;
I was trying different possible solutions
(Solution 1) Intention is to constraint axaddr[ (axsize-1):0 ] to all zeroes
constraint Addr_Aligned1 {
                              // axaddr[ (axsize-1):0 ] == 0; // Error-[IRIPS] Illegal range in part select
                               foreach( axaddr[i] )
                                 // if( i inside { [0:(axsize-1)] } ) // [Q] What if axsize == 0 ? What will result of ( axsize - 1 )
  be ?
                                 if( i < axsize )
                                   axaddr[i] == 0;
[Q1] If I change if - constraint to :: if( i inside { [0:(axsize-1)] } ) and add in-line constraint ::
if( obj.randomize() with { axsize == 0; } ) ,
I observe that the o/p is tool dependent.
When axsize is 0 , what would be the upper bound of [0:(axsize-1)] ? Will it be all ones ?
Is the result dependent on the type ( signed/unsigned ) of “i” ?
(Solution 2) Intention is to constraint axaddr & ( '1 << axsize ) ( which gives result as axaddr[ (axsize - 1) : 0 ] ) as 0
 rand bit[2:0] local_axsize ; // helper variable
    function bit[2:0] No_of_Zeroes( bit[2:0] ip );
      No_of_Zeroes = '1; // All Ones
      return( No_of_Zeroes << ip );
    constraint Addr_Aligned2  {
                                local_axsize == No_of_Zeroes(axsize);
                                ( axaddr & local_axsize ) ; // Need help here. Should there be RHS ?
Result of ( axaddr & local_axsize ) is 12-bit with lower ‘axsize’ no. of bits as 0.
One valid solution is axsize == 0 and axaddr as unconstrained ( including 0x0 )
i.e each address would be aligned to 1-byte
However axsize == 0 and axaddr == 0 won’t be picked via constraint axaddr & local_axsize ( as result is 0 ). The intention is that axsize == 0 and axaddr == 0 should also be picked as a possible solution.
[Q2] How should I use result of local_axsize in order to constraint axaddr accordingly ?
[Q3] Any suggestions for alternative solution are welcome as well
Use a mask
constraint align {
  ( axaddr & ( 1'b1 << axsize ) - 1 ) == '0;
You could use modulo operator:
constraint aligned{
axaddr % (2**axsize) == 0;
Thank you both Dave and Kranthi.
@dave_59 a question regarding above foreach constraint
     if( i inside { [0:(axsize-1)] } ) // confusion here
         axaddr[i] == 0;
[Q] If axsize is chosen as 0 , would there be any constraint on axaddr ?
Since (axsize-1) would be -1 shouldn’t there be a warning/error message ?
( as the range for inside operator must be [low:high] )
If axsize ==0, then there is no constraint on axaddr, which is the correct thing to do.
Yes I do agree but I was curious on how the constraint solver interprets the if-constraint
I tried the following
module tb;
  bit[11:0] axaddr;
  bit[2:0] axsize ; // Defaults to 0
       $display("i is %0d N (axsize-1) is %0h",i,(axsize-1));
I observe “(axsize-1) is ffffffff” i.e result is 32-bit (even though width of axaddr is 12-bit )
LRM 12.7.3 mentions
When loop variables are used in expressions other than as indices to the designated array, they are auto-cast into a type consistent with the type of index. For fixed-size and dynamic arrays, the auto-cast type is int .
Since the iterator argument “i” is int type i.e 32-bit signed type result of (axsize-1) would be FFFF_FFFF.
However shouldn’t this constraint all the bits of axaddr to 0 ? ( as the if condition would be always true )
        // Assuming 'axsize' is 0  via in-line constraint
            if( i inside { [0:(axsize-1)] } ) // Always true as i is inside {[0:FFFF_FFFF] }
               axaddr[i] == 0; // Shouldn't this constraint all bits to 0's ?
A 2nd possibility I see is that the inside constraint is ignored as range isn’t [low:high] thereby leaving axaddr unconstrained.
However I don’t observe any warning message for the invalid range.
I observe that the o/p is tool depended edalink
Yes, even experienced users like me get caught by the mixing of signed and unsigned types. So for axsize==0 all axaddr bits would be set to 0.
This is why we strongly encourage people to put in minimal,complete reproducible examples to get the best responses.
This made me realize that the range for the inside operator is still [low:high] due to result of (axsize-1) being 32-bit unsigned.
As axsize is bit type i.e unsigned type, (axsize-1) would be 32’hFFFF_FFFF i.e unsigned.
Hence the if-constraint would always be true and axaddr would be constrained to 12’b0.
