Consider,
typedef struct{
int english,maths,science;
string name;
}marks_t;
marks_t sheet;
sheet=‘{’{80,90,70,“John”},'{60,70,80,“Peter”}…};
Qn1: Is it possible to add the marks of all the 3 subject,to find whose total is greater than 200?
Qn2: How to sort the students who scored above 60 in english and maths?
In reply to Design Engineer:
For the sum you can refer to this 7.12.3 Array reduction methods .
class A;
typedef struct {
string name;
} mark_t;
mark_t sheet ;
mark_t q[$];
mark_t result[$];
int val ;
task process_stuct_data();
sheet = '{50,60,80,"john"};
q.push_back(sheet);
sheet = '{60,70,50,"peter"};
q.push_back(sheet);
sheet = '{70,60,90,"nathan"};
q.push_back(sheet);
result = q.find with ( item.english >= 60 && item.maths >= 60);
// find the sum
foreach(q[i]) begin
val = q.sum with ( item.index == i ? item.english + item.maths + item.science : 0);
if(val > 200) begin
$display("%p",q[i]);
In reply to kddholak:
Sorry,as i am new to SV,i don’t know how to proceed,I don’t know how to display the array and result
Plz find my code below and help me to work it out
module eg;
class A;
typedef struct {
string name;
} mark_t;
mark_t sheet ;
mark_t q[];
mark_t result[];
sheet = '{50,60,80,“john”};
q.push_back(sheet);
sheet = '{60,70,50,“peter”};
q.push_back(sheet);
sheet = '{70,60,90,“nathan”};
q.push_back(sheet);
$display(“value=%p”,sheet);
$display(“value=%p”,result);
A a1 = new ;
A a1=sheet;
foreach(a1.A[i])
$display(“%b”,a1.A[i]);`
I updated the array sum in original post. you will have to refer to LRM section of array.
Thanks a lot for ur support @ kddholak
Qn1:How to arrange the student mark list in descending order?
Qn2:How to find the student who has more mark in maths than english?
Qn3:How to find the first student with more than 50 marks in english?
you should be able to solve the rest of the question based on below example
7.12 Array manipulation methods, you should refer this chapter in LRM. Try to come with your solution.
Ya i have gone through the array manipulation methods.It helps me.
But i am stuck with descending order it.
I just came to know i have to use rsort()
But don"t know how to proceed.
Here is my code
module data;
typedef struct {
string name;
} mark_t;
mark_t sheet ;
mark_t q[];
mark_t result[];
int total;
int i;
q=‘{’{50,60,80,“john”},‘{60,70,50,“peter”},’{70,60,90,“nathan”}};
$display(“student list =%p”,q);
foreach(q[i]) begin
total = q.sum with ( item.index == i ? item.english + item.maths + item.science : 0);
if(total > 200) begin
$display(" above 60 in english,maths=%p",result);
result=q.find with (item.english>item.maths);
$display ("more marks in english=%p",result);
result=q.find_first with (item.english>50);
$display("english more than 50=%p",result);
**foreach(q[i])begin
q[i].rsort();** //How to do descending??
arrys all elements (stuck) will be sorted based on each argument
q.rsort with ({item.english, item.maths , item.science});
It works
Thanks a lot @ kddholak
