Within a component I have 2 analysis_imps ( using `uvm_analysis_imp_decl macro )
int assoc1[int];
int assoc2[int];
function void write_desc_req( req_pkt pkt);
assoc1[pkt.qid] += 1;
// Some logic
function void write_sqhd_req( req_pkt pkt);
assoc2[pkt.qid] += 1;
// Some logic
Now I am trying to debug the respective phase in which these associative arrays are being populated , so I decided to add a msg within the 2 write functions
uvm_phase ph;
ph = <Some_UVM_API> ; // Need suggestions here
`uvm_info("MY_DEBUG",$sformatf("assoc1['h%0h] incremented in %0s",pkt.qid,ph.get_name()),UVM_NONE)
// Some logic
uvm_phase ph;
`uvm_info("MY_DEBUG",$sformatf("assoc2['h%0h] incremented in %0s",pkt.qid,ph.get_name()),UVM_NONE)
// Some logic
Where ph.get_name() should return string types like ::
pre_reset / reset / post_reset / pre_configure / configure / post_configure /
pre_main / main / post_main / … / pre_shutdown / shutdown / post_shutdown
Does UVM provide any API to fetch the current uvm_phase ?
