I have a bit of a doubt on the soft constraints.
This is what LRM mentions about the soft constraint:
a constraint expression defined as soft designates a constraint that is to be satisfied unless contradicted by another constraint—either by a hard constraint or by a soft constraint with higher priority.
So, in the following code, is this a contradiction:
constraint deflt { soft length < 5 ; }
constraint new_const { soft length < 10 ; }
In the above example, would the soft constraint be overridden and only the new_const considered or both the constraints would be considered?
Similarly, what happens when the constraints are interchanged like below:
constraint deflt { soft length < 10 ; }
constraint new_const { soft length < 5 ; }
