ARM processor(32 bit) can write-32 bits of data each time. There is memory in the chip - 64 bit each location (Initial data = 64’b 0000000101) and memory depth=65 , each time you need to write shifted data (64’b110<<1) to each memory location . how can we write using c test ?
I have written below sample C-code . Can somebody confirm whether below answer is correct ??
int main(void) {
unsigned int *addr ;
unsigned int flag = 0;
addr = 0xFFAA_00F0 ;
*addr = 0x0; // Making initial value = 32'h0;
for (int i =0 ; i < 62 ;i++) {
if (i<=31) {
*addr = (0x6 << i) ;
addr++ ; // will point to next DWORD aligned address . 4 byte increment
addr++ ; // will point to next DWORD aligned address . 4 byte increment . Total 8 byte increment each time .
if (i == 31 ) flag =1 ;
else {
if (flag) {
addr++ ; // extra 4 byte increment to point data location 63:32
flag= 0;
addr++ ;
addr++ ;
return 0 ;
Problem statement is well described with below table of mem data . we have to write shifted 0x6 data to 64 bit memory locations . consider that ARM proc which has 32 bit data/address port , and there is interconnect which translate the 32 bit write req to 64 bit req to memory .
0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0110 //0th mem location
0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_1100
0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0001_1000
0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0011_0000
0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0110_0000
0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_1100_0000
0000_0000_0000_0000_0000_0000_0000_0000_1100_0000_0000_0000_0000_0000_0000_0000 //29 mem location-lower word access w.r.t 32 bit Proc .
0000_0000_0000_0000_0000_0000_0000_0001_1000_0000_0000_0000_0000_0000_0000_0000 //30 mem location-upper word access w.r.t 32 bit Proc .
0000_0000_0000_0000_0000_0000_0000_0011_0000_0000_0000_0000_0000_0000_0000_0000 //31 mem location-upper word access w.r.t 32 bit Proc .
0001_1000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000
0011_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000
0110_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000_0000 // 60th mem location location
Please find updated c driver code for above problem statement .
int main(void) {
addr = 0xFFAA_00F0 ; // lets say its initial address
for (int i =0 ; i < 61 ;i++) {
if (i<=30) {
*addr = (0x6 << i) ; // writting to lower dword memory .
if (i == 30 ) {
addr++ ; // extra 4 byte increment to point data location 63:32 from this point onward .
*addr = 0x1 ; // Making 30th location upper word as 0x1 as per problem statement
else {
if (i == 31 ) {
*addr = 0x3 ; // Making 31th location upper word as 0x3 as per problem statement
else { // writting shifted 0x6 to location > 31
*addr = (0x6 << (i-32)) ;
return 0 ;
