Hi I am trying to clean up legacy code in SV. The way signals are hookup between monitor and RTL is through bind
bind rtl_top a_monitor a_monitor_u(
.abc ({`PATH_TO_MODULE0.sig1,
`PATH_TO_MODULE1.sig2,
`PATH_TO_MODULE2.sig3,
`PATH_TO_MODULE3.sig4,
`PATH_TO_MODULE4.sig5
in monitor abc is defined as an array
bit abc [5];
Is there a cleaner way to handle RTL signal declaration? If in next project MODULE increases to 20, have to manually add lines of code.
There is no interface defined, so cant use interface to pass signals
