hi, i’m trying to write a coverpoint as follows:
covergroup cg with function sample (bit a, bit [31:0] d_in); c_c1: coverpoint d_in iff (a==1){ bins d_in_1[] = {['hd0000000:'hd0003def]} with (item [4:3] == 1); }
i’m getting the following error: Hierarchical name component lookup failed at ‘item’.
can anyone see the problem?
thanks, Gidon
In reply to gidon:
I believe you found a tool bug. Works for me in at least two other simulators. A workaround would be
bins d_in_1[] = {['hd0000000:'hd0003def]} with (item ==? 'b1101_0000_0000_0000_????_????_???0_1???);
In reply to dave_59: thanks Dave.
eventually I used this:
covergroup cg with function sample (bit a, bit [31:0] d_in); c_c1: coverpoint d_in iff (a==1){ bins d_in_1[] = {['hd0000000:'hd0003def]} with ((item & 'h00000018) == 1); }
