hello,
I am trying to use the “bins with” syntax in the following manner, for some reason the simulation gets stuck during elaboration. when removing this syntax, the simulation completes normally, what can be the cause?
cp_cfg_channel_num: coverpoint chid
/ CP USER DESCRIPTION: 0-26,31 */
// `include “channels_indexing.inc”
// bins channel_id = cp_cfg_channel_num with (epi_proj_coverage_pkg::valid_chid(item));
**bins channel_id = cp_cfg_channel_num with (item inside {epi_proj_coverage_pkg::valid_chid()});
** type_option.weight = 0;
typedef int bins_q[$];
// this function returns 1 if chid should be covered
function automatic bins_q valid_chid();
bins_q ret_item;
// in Hawk, the valid chid are 0-26 & 31
for (int chid=0; chid<27; chid++) begin
ret_item.push_back(chid);
ret_item.push_back(31);
return ret_item;
endfunction : valid_chid
thanks in advance.
