IMPORTANT NOTICE: Please be advised that the Verification Academy Forums will be offline for scheduled maintenance on Sunday, November 8th at 3:00 AM US/Pacific.
Here is my question. I am trying to verify 2 port RAM.
I have one rd_agent hooked to one of the interface and wr_agent hooked to other interface. so read_sequence should only issue a read to a address to which write_agent has already initialized the value.
I need some communication mechanism between 2 sequence. How do I achieve this?
I usually use uvm_event_pool to communicate between components or sequences. uvm_event_pool also let you pass a data value from a sequence to another. Simple idea:
read_sequence waits for a event (uvm_event) to be triggered using wait_trigger_data(address) task before it issues a read to address which is received from wait_trigger_data task.
write_sequence initializes a value to address, then trigger and send address value to read_sequence using trigger(address) function.
Ideally you would use a virtual sequence. The purpose of a virtual sequence is to co-ordinate the execution of sub-sequences, which includes sharing required data between them, such as addresses.
You should never use event pools as these introduce unnecessary complexity and reduces the re-usability of these sequences.
