I need some help regarding the setting of interface to config db in top tb module and which in turn set into agent from env.
basically my implementation is shown as below
module top_tb;
// ports
// i have a genvar for loop
genvar i;
for (i=0; i<5; i++) begin : gen
//interface instance
xyz_if m_if;
//module instance to which the interface is passed
module1 m1(m_if);
// i am trying to set the same if into config db here
if(i==1)
uvm_config_db#(virtual xyz_if)::set(uvm_root::get(), "uvm_test_top.env*", "vif", m_if);
end //for loop
will this work, please help.
other process i tried is below, after for loop i added this way
for (int i =0; i<3; i++) begin
uvm_config_db#(virtual xyz_if)::set(uvm_root::get(), "uvm_test_top.env*", "vif", gen[i].m_if);
i am getting error at gen[i] place.
help me to use the correct way
You don’t mention what kind of error you are getting (compilation, run time, wrong value, etc), so these are some general recommendations:
Only target uvm_test_top with your interface handle
Use ‘null’ for context when at the top testbench level
Don’t use ‘*’ for a target as this can result in conflicts
Every string name used should be unique so that the test can assign the correct interface handle to the correct agent
In your test, get each handle and assign it to each agent’s (or environment) configuration object
module top_tb;
// ports
genvar i;
xyz_if m_if;
module1 m1(m_if);
uvm_config_db#(virtual xyz_if)::set(null, "uvm_test_top", $sformatf("vif%0d",i), m_if);
end //for loop
It is recommended to have a configuration object for each agent. This configuration object contains all the information used by the agent to control its behavior. Part of this configuration object should be the virtual interface handle to be used by the agent.
The environment configuration object will contain all the agent configuration objects. It is created as part of the test and passed to the environment, which will then pass the agent configuration objects to the correct agent.
