In reply to jaswanth_b:
You don’t mention what kind of error you are getting (compilation, run time, wrong value, etc), so these are some general recommendations:
- Only target uvm_test_top with your interface handle
- Use ‘null’ for context when at the top testbench level
- Don’t use ‘*’ for a target as this can result in conflicts
- Every string name used should be unique so that the test can assign the correct interface handle to the correct agent
- In your test, get each handle and assign it to each agent’s (or environment) configuration object
module top_tb;
// ports
// i have a genvar for loop
genvar i;
for (i=0; i<5; i++) begin : gen
//interface instance
xyz_if m_if;
//module instance to which the interface is passed
module1 m1(m_if);
// i am trying to set the same if into config db here
uvm_config_db#(virtual xyz_if)::set(null, "uvm_test_top", $sformatf("vif%0d",i), m_if);
end //for loop
