Hello Everyone,
I have a reg_seq_base that needs to get the env_config object from the config_db.
The config object has been set() from the base_test build phase. Like this,
uvm_config_db #(apb2spi_env_config) :: set(this, "*", "CONFIG_DATA_ENV", env_config);
The base_test also has the reg_base_seq handle,
reg_seq = reg_base_seq::type_id::create("reg_seq");
and would be run in the base_test run_phase as,
reg_seq.start(null)
In the sequence body task I tried to get() the env_config from the config db. But it is not working.
if(!uvm_config_db #(apb2spi_env_config)::get(null, get_full_name(), "CONFIG_DATA_ENV", env_config)) `uvm_fatal("body", "Could not find apb2spi_env_config")
ABD_91
July 19, 2023, 8:27am
2
In reply to Husni Mahdi :
For the sequence ( reg_seq = reg_base_seq::type_id::create(“reg_seq”); ) :
Since the parent_sequence and m_sequencer are both null , change your set to :
uvm_config_db #(apb2spi_env_config) :: set(null, "reg_seq", "CONFIG_DATA_ENV", env_config);
In reply to ABD_91 :
Will this not prevent the environment from getting the config?
ABD_91
July 19, 2023, 11:11am
4
Yes , the env/agent/… won’t be able to fetch the config .
Your initial question was regarding the sequence fetching the resource , so my solution was based on that .
cgales
July 19, 2023, 12:26pm
5
Since uvm_objects don’t have hierarchical paths, it can difficult to use the config_db.
The simplest solution is to assign the configuration object when the sequence is created.
reg_seq.env_config = env_config;
reg_seq.start(null);
Use get_sequencer() and get_sequence_path() instead of get_full_name().
uvm_config_db #(apb2spi_env_config)::get(get_sequencer(), get_sequence_path(), "CONFIG_DATA_ENV", env_config);
https://verificationacademy.com/forums/uvm/configuration-sequences-started-virtual-sequence
https://verificationacademy.com/forums/uvm/question-configuration-uvm-sequences#reply-113780
ABD_91
July 19, 2023, 4:30pm
7
In reply to Orimitsu :
That still won’t work with the way configuration is set from test :
Yeah. You are right.
The sequence start part in the test class below
should have been like the following.
reg_seq.start(.sequencer(<handle of your sequencer>), .parent_sequence(null) );
You need to specify the sequencer on which the sequence starts.
The sequence identification path is [Component path of the sequencer].[Sequence Path].
