I have a single monitor class that I use for multiple agents. Some agents are for my UDP_in_x, TCP_in_x, UDP_out_x, TCP_out_x. This monitor class has a uvm_analysis_port and connects to a scoreboard with many analysis_imps. The issue I am having is that the in’s and out’s are an array of agents. So I named them udp_in_0, … udp_in_n. Same for the rest. When writing to the scoreboard, I use a write(item) function and then based on the name I pass to the monitor, I write to a function in the scoreboard for that interface, so write_udp_in(item), write_tcp_in(item), write_tcp_out(item), etc. The issue is that I need to know if its udp_in_0, or 1 or 2 etc. to determine which queue to put the item in when I write the item in the scoreboard. Essentially what Id like to do is turn the monitor as generic as possible. and I can’t find the best way to do this with a single monitor class. The best approach I have to do this is below.
if (contains(my_name,"udp_out")) begin
item.inf_type = "udp_out";
if(contains(my_name,"_0")) item.inf_id = 0;
if(contains(my_name,"_1")) item.inf_id = 1;
if(contains(my_name,"_2")) item.inf_id = 2;
if(contains(my_name,"_3")) item.inf_id = 3;
if(contains(my_name,"_4")) item.inf_id = 4;
if(contains(my_name,"_5")) item.inf_id = 5;
if(contains(my_name,"_6")) item.inf_id = 6;
if(contains(my_name,"_7")) item.inf_id = 7;
The inf_type is to determine in scoreboard what type of interface is writing to the scoreboard.
However this is very much not UVM like. And redundant for other interfaces. Additionally I have to add more name checking for when the inf_id exceeds 7.
Here is a portion of what my scoreboard imps look like,
uvm_analysis_imp #(Item_Mon_to_Scrb, my_scoreboard) m_analysis_imp0 [UDP_COUNT-1:0]; // udp_in
uvm_analysis_imp #(Item_Mon_to_Scrb, my_scoreboard) m_analysis_imp9 [UDP_COUNT-1:0]; // udp_out
Maybe I am thinking of this totally wrong, but it would be best if there is a way for the scoreboard to see which analysis_port is writing to it, and then can get its name and number from the connection to the monitor.
