Hi all,
I had witten code for counter in UVM. As I am new to system verilog and UVM i had followed uvm_tutorial_for_candy_lovers_master code to implement counter in uvm. I had compiled uvm counter code in questasim 10.0c simulator and i found some run time errors as mentioned below. Can anyone help me out to resolve this errors.
run time error report:
vsim -novopt top
Refreshing D:\baban123_uvm\work.top
Refreshing D:\baban123_uvm\work.uvm_count_mod_8915_can_sv_unit
Loading sv_std.std
Loading mtiUvm.uvm_pkg
Loading work.uvm_count_mod_8915_can_sv_unit
Loading work.top
Refreshing D:\baban123_uvm\work.Bus_if
Loading work.Bus_if
Refreshing D:\baban123_uvm\work.Counter
Loading work.Counter
** Error: (vsim-3567) uvm_count_mod_8915_can.sv(345): No field named ‘start’.
Region: /uvm_count_mod_8915_can_sv_unit
** Error: (vsim-3996) uvm_count_mod_8915_can.sv(345): Formal ‘start’ does not exist in call start.
** Error: (vsim-3978) uvm_count_mod_8915_can.sv(345): Cannot assign an unpacked type to a packed type.
Time: 0 ns Iteration: 0 Region: /uvm_count_mod_8915_can_sv_unit File: uvm_count_mod_8915_can.sv
Error loading design
/////////////////// code is here ////////////////////////////
`include “uvm_macros.svh”
import uvm_pkg::;
module Counter(clk,reset,data);
input wire clk,reset;
output reg [3:0] data;
always @ (posedge clk)
if(reset)
data<=0;
data<=data+1;
endmodule: Counter definition
interface Bus_if;
wire clk;
wire reset;
reg [3:0] data;
endinterface:Bus_if
module top();
//generate the clock
reg clk = 0;
forever #5 clk = ~clk;
//interface instance
Bus_if Bus_if1();
// Dut instance
Counter Counter1(Bus_if1.clk,Bus_if1.reset,Bus_if1.data);
//set virtual interface
uvm_config_db#(virtual Bus_if)::set(null,“*”,“Bus_if1”,Bus_if1);
run_test();
endmodule: top
class counter_trans extends uvm_sequence_item;
rand bit reset;
rand bit data;
function new(string name="");
super.new(name) ;
`uvm_object_utils_begin(counter_trans)
`uvm_field_int ( reset,UVM_ALL_ON )
`uvm_field_int ( data, UVM_ALL_ON )
`uvm_object_utils_end
endclass:counter_trans //used for generating stimulus
//counter sequence definition is here
class count_seq extends uvm_sequence#(counter_trans);
`uvm_object_utils(count_seq)
virtual Bus_if Bus_if1;
super.new(name);
void'(uvm_config_db#(virtual Bus_if)::get(this,"*","Bus_if1",Bus_if1));
if(!uvm_config_db#(virtual Bus_if)::get(this,"* ","Bus_if1",Bus_if1)) begin
`uvm_error("","uvm_config_db::get failed in driver");
task body();
counter_trans req;
req=counter_trans::type_id::create("req",this);
if(Bus_if1.clk) begin
start_item( req.randomize() );
finish_item(req);
else if (!req.randomize()) begin
`uvm_error("MY_SEQUENCE", "Randomize failed.");
endclass:count_seq
//sequencer defination
class counter_sequencer extends uvm_sequencer # (counter_trans);
`uvm_component_utils(counter_sequencer)
counter_sequencer sqr;
count_seq seq;
super.new(name);
task body();
seq=count_seq::type_id::create("seq",this);
seq.start(.counter_sequencer(sqr),.parent_sequence(this));
join
endclass:counter_sequencer
class driver extends uvm_driver # (counter_trans);
`uvm_component_utils(driver)
function new(string name,uvm_component_parent="null");
super.new(name,null);
super.build_phase(phase);
counter_trans req;
forever begin
// gets the sequence item from the counter_trans
if(Bus_if1.clk)
Bus_if1.reset <= req.reset;
Bus_if1.data <= req.data;
seq_item_port.item_done();
endclass:driver
class monitor extends uvm_monitor;
`uvm_component_utils(monitor)
uvm_analysis_port#(counter_trans) ap_objseq;
function new(string name, uvm_component_parent="null");
super.new(name, null);
ap_objseq = new(.name("ap_objseq"),.parent(this));
forever begin
counter_trans req;
@ Bus_if1.clk;
req.reset = Bus_if1.reset;
req.data = Bus_if1.data;
ap_objseq.write(req);
endclass:monitor
class coverage extends uvm_subscriber # (counter_trans);
`uvm_component_utils(coverage)
counter_trans req;
covergroup count_cov;
coverpoint req.reset;
coverpoint req.data;
endgroup
count_cov = new();
function void write(counter_trans cov_tx);
req = cov_tx;
count_cov.sample();
endclass:coverage
typedef class scoreboard;
class counter_subscriber extends uvm_subscriber # (counter_trans);
`uvm_component_utils(counter_subscriber)
function new (string name, uvm_component_parent="null");
function void write(counter_trans sb_t);
// scoreboard cnt_sb;
$cast(cnt_sb,m_parent);
endclass:counter_subscriber
class scoreboard extends uvm_scoreboard;
`uvm_component_utils(scoreboard)
uvm_analysis_export # (counter_trans) ap_objseq_export;
scoreboard sb;
local counter_subscriber counter_sub;
rand bit store;
function void build_phase (uvm_phase phase);
if (!uvm_config_db#(virtual Bus_if)::get(this,"*","Bus_if1",Bus_if1)) begin
`uvm_error("","uvm_config_db::get failed in Scoreboard");
ap_objseq_export = new(.name("ap_objseq_export"),.parent(this));
counter_sub=counter_subscriber::type_id::create("counter_sub",this);
super.connect_phase(phase);
ap_objseq_export.connect( counter_sub.analysis_export );
counter_trans req;
if(!req.reset) begin
sb.store = sb.store+1;
else begin
sb.store = 0;
if(sb.store==req.data) begin
`uvm_info("","test has been passed","UVM_LOW");
endclass:scoreboard
//agent defination
class agent extends uvm_agent;
`uvm_component_utils(agent)
uvm_analysis_port # (counter_trans) ap_objseq;
// virtual Bus_if Bus_if1;
driver drv;
monitor mtr;
scoreboard sb;
coverage cov;
counter_subscriber count_sub;
drv = driver::type_id::create("drv",this);
mtr = monitor::type_id::create("mtr",this);
sb = scoreboard::type_id::create("sb",this);
cov = coverage::type_id::create("cov",this);
sqr = counter_sequencer::type_id::create("sqr",this);
drv.seq_item_port.connect(sqr.seq_item_export);
mtr.ap_objseq.connect(ap_objseq);
ap_objseq.connect(cov.analysis_export);
endclass:agent
// environment defination
class environment extends uvm_env;
`uvm_component_utils(environment)
agent agt;
coverage cov;
scoreboard sb;
agt = agent::type_id::create("agt",this);
cov = coverage :: type_id::create("cov",this);
sb = scoreboard :: type_id::create("sb",this);
agt.ap_objseq.connect(sb.ap_objseq_export);
endclass:environment
class test_count extends uvm_test;
`uvm_component_utils(test_count)
environment env;
env = environment::type_id::create("env",this);
counter_sequencer v_sqr;
phase.raise_objection(this);
v_sqr = counter_sequencer::type_id::create("v_sqr",this);
v_sqr.sqr = env.agt.sqr;
v_sqr.start(.counter_sequencer( null ));
#10ns
phase.drop_objection(this);
endclass:test_count
