How can we change runtime configuration of configuration class?
I’m working on IIS protocol VIP. I took configuration class in environment. Configuration class is having data width, no_transaction, and sampling edge variables. i want to change this configuration values on runtime using single testcase. How can i do it?
(i’m using EDA playground with VCS tool)
what I know as per my experience is that configuration class should contain values which are same/constant through out simulation.In UVM, before end_of_elaboration phase, you can configure as per your need. if you want to change something at run time, then you can use run time arguments which are $test$plusargs and $value$plusargs.
In reply to K_123:
what exactly you want to do? I can create small example for demonstration.
In reply to juhi_p:
Yes, that would be helpful
In reply to K_123:
small_uvm_tb - EDA Playground . check here.
In reply to juhi_p:
Thanks juhi_p,
actually i’m working on systemverilog (i forgot to tell you earlier) but i’m trying to figure out from your code. and you used $value$plusargs but it works on command line arugument only. if you have any suggestion please tell.
In reply to K_123:
What do you mean to say you’re not using UVM? If that’s so then we’re not sure what you mean by configuration class. Can you show us an example?
I’m working on i2s protocol VIP using systemverilog.
this is the link of my configuration class. i’m using all this configuration in my transaction, generator and driver.
