Firstly, apologies for lengthy question. As I’m a beginner in UVM and SystemVerilog any suggestion and constructive criticism is welcome!!
class ahb_sequence extends uvm_sequence#(type ahb_p_req = ahb_packet, type ahb_p_rsp = ahb_p_req);
`uvm_sequence_utils(ahb_sequence,ahb_sequencer)
req = ahb_p_req::type_id::create("req");
int inc_undef_burst_hwrite;
function new (string name ="ahb_sequence");
super.new(name);
endfunction : new
virtual task body();
uvm_report_info("seq","before uvm_do",UVM_NONE);
/// vvv ///
start_item(req);
if(!req.randomize())
`uvm_error("seq", "randomization failure for req")
int inc_undef_burst_hwrite = req.hwrite;
if (req.hburst != 0 && req.trans=='d2) // Entering BURST mode write/read transaction
casez(req.hburst) // case for one of the burst operation, in our DUT please ignore the wrapping burst
3'b01?:
repeat(3) // 4-beat incrementing burst (INCR4), we use repeat 3, as first transfer has already been initiated
finish_item(req);
get_response(rsp); // complete of first transfer of Burst and from next cycle address will be incrementing by one
start_item(req);
if (req.htrans==2)
req.trans='d3;
if (req.hwrite==1)
req.randomize(hwdata); // radomize only H-WRITE-DATA if its a write Burst operation
3'b10?:
repeat(7) // 8-beat incrementing burst (INCR8), we use repeat 7, as first transfer has already been initiated
finish_item(req);
start_item(req);
if (req.htrans==2)
req.trans='d3;
if (req.hwrite==1)
3'b11?:
repeat(15) // 16-beat incrementing burst (INCR16), we use repeat 15, as first transfer has already been initiated
finish_item(req);
start_item(req);
if (req.htrans==2)
req.trans='d3;
if (req.hwrite==1)
3'b001:
do
finish_item(req);
start_item(req);
if (req.htrans==2)
req.trans='d3;
req.randomize(hwrite);
while(inc_undef_burst_hwrite == req.hwrite)
endcase
finish_item(req);
get_response(rsp); // type of rsp = my_sequence_item2
endtask : body
endclass : ahb_sequence
class ahb_driver extends uvm_driver#(type ahb_p_req = ahb_packet, type ahb_p_rsp = ahb_p_req);
`uvm_component_utils(ahb_driver)
//Interface and packet declaration
virtual ahb_if vif;
// ahb_packet pkt; vvv
super.new(name, parent);
endfunction: new
super.build_phase(phase);
void'(uvm_resource_db#(virtual ahb_if)::read_by_name(.scope("ifs"),.name("ahb_if"), .val(vif)));
uvm_config_db#(virtual interface ahb_if)::get(this,"*","ahb_if",vif);
endfunction: build_phase
@(posedge vif.HRESETN)
while(1)
//Drive the packet at the negative edge of clock
@(negedge vif.HCLK)
uvm_report_info(get_full_name(),"Printing the AHB packet",UVM_NONE);
req.print();
@(posedge vif.HCLK)
vif.HWRITE = req.hwrite;
vif.HADDR = req.haddr;
if(req.hwdata==1)
vif.HWDATA = req.hwdata;
vif.HTRANS = req.htrans;
vif.HSIZE = req.hsize;
vif.HBURST = req.hburst;
seq_item_port.item_done();
//vvv
rsp = ahb_p_rsp::type_id::create("rsp"); // type of rsp = ahb_p_rsp
rsp.set_id_info(req);
rsp.hresp = vif.HRESP;
if(vif.HRESP)
`uvm_error("seq", "Error in transfer response from slave")
seq_item_port.put(rsp);
//vvv
endtask: run_phase
endclass: ahb_driver
class ahb_scoreboard extends uvm_scoreboard;
`uvm_component_utils(ahb_scoreboard)
uvm_analysis_imp #(ahb_packet,ahb_scoreboard) scb_port;
ahb_packet ahb_scpkt;
logic[31:0] stor_assos[*] ;
logic[31:0] burst_addr[$];
logic[31:0] burst_addr_temp;
function compare (string name,uvm_component parent);
scb_port = new("scb_port",this);
endfunction : compare
function new (string name,uvm_component parent);
super.new(name,parent);
endfunction : new
virtual function void connect();
super.connect();
uvm_report_info("scb","connect method in scoreboard",UVM_NONE);
endfunction : connect
virtual task run_phase (uvm_phase phase);
endtask : run_phase
virtual function write(ahb_packet ahb_mpkt);
uvm_report_info("scb","received packet from Monitor",UVM_NONE);
ahb_scpkt = new();
$cast(ahb_scpkt,ahb_mpkt.clone());
ahb_scpkt.print();
/// vvv ///
if(ahb_scpkt.hresetn =='b1 )
if(ahb_scpkt.hwrite == 'b1)
case(ahb_scpkt.htrans)
2b'10:
stor_assos[ahb_scpkt.haddr] = ahb_scpkt.hwdata; // Copy WRITE operation for non-BURST WRITE
if(ahb_scpkt.hburst != 0)
burst_addr.push_back(ahb_scpkt.haddr); // Since we do not know the next cycle will be Burst READ we save the current memory address
break;
2b'11:
casez(ahb_scpkt.hburst)
3'b01?:
repeat(3)
burst_copy(ahb_scpkt);
break;
3'b10?:
repeat(7)
break;
3'b11?:
repeat(15)
break;
3'b001:
while(ahb_scpkt.hwrite == 'b1)
break;
default:
uvm_report_error("scb","Condition not valid");
endcase
break;
default:
uvm_report_info("scb","HTRANS is either 2'b00 or 2'b01 so need not write",UVM_NONE);
endcase
if(stor_assos.exists[ahb_scpkt.haddr])
2b'10:
if (stor_assos[ahb_cmp_pkt.haddr] == ahb_cmp_pkt.hrdata) // Compare for non-burst read operations
uvm_report_info("scb","Read data matches the written data",UVM_NONE);
uvm_report_error("scb","Read data does not matches the written data");
break
2b'11:
3'b01?:
repeat(3)
burst_compare(ahb_scpkt);
break;
3'b10?:
repeat(7)
break;
3'b11?:
repeat(15)
break;
3'b001:
while(ahb_scpkt.hwrite == 'b0)
break;
default:
endcase
break;
default:
endcase
/// vvv ///
endfunction : write
function void burst_compare (ahb_packet ahb_cmp_pkt)
burst_addr_temp = burst_addr.pop_back(); // Pop the previous address
burst_addr_temp++; // Increment by one
if (stor_assos[burst_addr_temp] == ahb_cmp_pkt.hrdata)
burst_addr.push_back(burst_addr_temp); // Save the new adress in the Queue
function void burst_copy (ahb_packet ahb_cpy_pkt)
stor_assos[burst_addr_temp] = ahb_cpy_pkt.hwdata; // Save in memory location
endclass : ahb_scoreboard
