I have a question
1# I want to return a structure from c-model to the SV my structure is here
In SV:
typedef struct {
string res_data;
string res_add;
}rfi;
In C:
typedef struct {
char res_data[32];
char res_add[32];
}rfi;
and imported in SV using
import “DPI-C” function rfi ref_model(string inst);
I’m getting an error says “unpacked struct can’t be return type”
So when I use
In SV:
typedef struct packed{
string res_data;
string res_add;
}rfi;
getting error:“string can’t be in packed struct”
2# How to return a string type to SV from C?
i’m using::
import “DPI-C” function string ref_model(string inst);
string result;
result=ref_model(inst);
when I print result the simulator(VCS) gets terminating without printing the result…
appreciate if any experts help me, thank you.
