Regarding Method Overriding / Polymorphism SystemVerilog
In reply to ziggy:
$cast does not create or copy objects; it tries to copy a handle from one class variable to another. Please see my course on SystemVerilog OOP, especially the second session.
So in the above code I have posted, Class A’s handle ‘a’ is created by ‘new’. Then I do a $cast(b,a). Why is there an error ‘type mismatch’?
But the following code works and why is that?
class A;
   int a=10;
   virtual function void disp();
     $display("Base a=%d",a);
class B extends A;
  int a=20;
    $display("Derived a=%d",a);
module tb();
  A a;
  B b=new;
    b=a;
    $cast(b,a);
    b.disp();               //
    $display("b.a=%d",b.a); //
    a.disp();               //
    $display("a.a=%d",a.a); //
In reply to ziggy:
The code you just posted does not work. Did you simulate it?
b=a; // should give you a compile error
b.disp(); // should be a run time fatal because b has a null handle.
Sorry it was a typo
Its “a=b” and not “b=a”
In reply to ziggy:
Have you looked at my course yet?
Your sv-class-OOP courses are excellent !! Heavily loaded with important information. The way you described all of them seamlessly is awesome!
can you share more courses… how we can access them
