Regarding implication operator in SVA
Hello,
I’m not very familiar with ABV and SVA, but someone a while back mentioned about avoiding the implication operator in cover properties
the person was not able to elaborate his answer, so I’d like to know if this is correct? If so that means that cover properties should be always written something like
a##0b //for a->b
or
a##1b //for a=>b
The other question is related to chained implication operator
a->b->c
my understanding is that in case of a occurring but b never happening this type of assertion will not fail, is this the case and why?
Regards,
-R
In reply to rgarcia07:
Hello,
a##0b //for a->b
or
a##1b //for a=>b
The cover property is typically used to cover in tests critical sequences. For example, you want to insure that in testing a FIFO that you address the sequence fifo_full ##1 push ##0 !pop;
The assertion of properties is typically provided by the tool.
a->b->c
Regards,
-R
 b |-> c; if b==0 the property is vacuous.
a |-> (b |-> c) if a==1 you check the property (b |-> c) ;
There, if b==0 the property is vacuous.
I do not recommend the use of multiple implication operators. You can write multiple small assertions.
Ben systemverilog.us
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
  • Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712
  2. SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy
Thank you very much for your explanation Ben.
