Without constructing the new() construct, how to access the task &/or function of a particular class.?
with using static method one can access task or function defined in class without allocating memory.
code for refference
program test();
class a;
static int p;
static task display();
int b=1;
int c=1;
p=p+3;
c=c+1;
$display("value of p=%d b=%d c=%d",p,b,c);
initial
a A=new;
A.display(); // without creating instance, i am able to access the display method // Why ?
endprogram
A static method can be invoked without the need for creating an instance of a class.
module example();
class static_ex;
int a;
a++;
$display("Welcome to static world");
$display("A is %0d",a);
initial
static_ex stat_h;
//Choice 1: Using scope resolution
static_ex::display();
//Choice 2: Using class handle
stat_h.display();
Any of the above two choices will satisfy your requirement.
Regards,
Vinay
May I know under what scenarios one might need to do this?
In reply to tejapan:
See my SystemVerilog OOP course for examples of how the UVM uses static class members.
