Hi ,
Assume i have register Reg_A[31:0] which contains 3 fields Filed_A[7:0] Field_B[15:8] , Filed_C[23:16] and Field_D[31:24].
Field_A,Field_B, Field_C are configure with access_rights = “RO” type, while Filed_D is configured with “RESERVED”. In the reg_block while i am adding Reg_A_inst (using add_reg function), It can be added with access_rights = “RW” ? What would be side-effects if i do so ?
Saravanan
