Realtime rounding in assertion
I am having the hardest time figuring out how realtime boolean expression rounding occurs. Given the following code:
`timescale `1ns/1fs
`define CLK350_PERIOD_L 2.857000ns
`define CLK350_PERIOD_H 2.857286ns
property p350Mhz(clk);
   realtime current_time;
   @(posedge clk)
   (1,current_time=$realtime) |=> (`CLK350_PERIOD_L <= $realtime-current_time && $realtime-current_time <= `CLK350_PERIOD_H);
Into this property, I am passing in a clock whose period measures 2.857ns exactly (from sim waveform set at fs scale). However the assertion continues to fail despite the fact that 2.857ns should fall with the _L and _H macros that I have specified…
I have also tried dividing all $realtime calls by 1fs:
   @(posedge clk)
   (1,current_time=$realtime/1fs) |=> (`CLK350_PERIOD_L <= $realtime/1fs-current_time && $realtime/1fs-current_time <= `CLK350_PERIOD_H);
Does the boolean expression $realtime-current_time get rounded somehow due to timeunit? How can I get the assertion to not fail?
In reply to ce_2015:
Equality is difficult to achieve when using real numbers.
See Why 0.1 Does Not Exist In Floating-Point - Exploring Binary
But I’m just trying to do less than or equal to/greater than or equal to… not exact equality…
Is there a better recommendation for verifying clock frequency tolerances with assertions?
You are in the equal part of “less than or equal”. You should work in ps to remove any rounding errors or adjust your values away from equal. i.e.
`define CLK350_PERIOD_L 2.85699ns
