Hi all,
I am learning SystemVerilog right now. I want to understand randomize() method by implementing the following:
→ Generate a random array of 32 bits with following constraints:
- There are no 0’s in between 1’s.
- if it is a nonzero value, the LSB must be 1
- Example : 0x00000000, 0x00000001, 0x00000003, 0x00000007, 0x0000000F … 0xFFFFFFFF
Can someone help me with right constraints?
Thanks.
In reply to stupidkris1010:
I am using this one which works fine, but looking for comments to optimize it further/ find other efficient way:
task randomize_list;
bit list[];
list = new[32];
$display("Random list:\n");
randomize(list) with {
list.sum < 32;
foreach(list[i]) if(i>0 && list[i]) list[i-1] != 1'b0;
for(int i=0;i<32;i++)
$display("%1b", list[i]);
It would be much easier to write this as a packed array instead of an unpacked array.
bit [31:0] list;
int unsigned shift;
initial repeat (50) begin
randomize(list,shift) with {
list == (32'b1 << shift) -1;
shift <=32; };
$display("%5d %b",shift, list);
I can’t really say which is more efficient in terms of performance.
Surely it is much easier. Thanks for providing this solution :)
