Hi All,
I have an 8-bit vector in this vector I need to get continuous ones in four places, e.g., 00111100, 11110000, 00001111 like this.
I have written a constraint for the above question, But I am seeing a randomization failure Can anyone help why my constraint is conflicting?
class ones;
rand logic [7:0] a;
rand int unsigned b[4];
constraint c {
solve b before a;
foreach(b[i])
if(i != 0)
b[i] inside {[0:7]}; //Constraining helper array values in between 0 to 7
b[i] == b[i-1] + 1; // current array value is greater than previous array value + 1
foreach(a[j])
if( j == b[i])
a[j] == '1;
a[j] == '0;
initial
ones o;
o = new();
assert(o.randomize());
$display("%p, %b", o.b, o.a);
run -all
** Warning: License feature ‘svverification’ will expire today.
testbench.sv(51): randomize() failed due to conflicts between the following constraints:
testbench.sv(24): c { if ((!(7 == b[0]))) {(~a[7]);} }
testbench.sv(24): c { if ((!(6 == b[0]))) {(~a[6]);} }
testbench.sv(24): c { if ((!(5 == b[0]))) {(~a[5]);} }
testbench.sv(24): c { if ((!(4 == b[0]))) {(~a[4]);} }
testbench.sv(24): c { if ((!(3 == b[0]))) {(~a[3]);} }
testbench.sv(24): c { if ((!(2 == b[0]))) {(~a[2]);} }
testbench.sv(24): c { if ((!(1 == b[0]))) {(~a[1]);} }
testbench.sv(24): c { if ((!(7 == b[1]))) {(~a[7]);} }
Given:
bit [31:0] b[0]
logic [7:0] a
bit [31:0] b[1]
** Note: (vsim-7130) Enabling enhanced debug (-solvefaildebug=2) may generate a more descriptive constraint contradiction report and -solvefaildebug testcase.
** Note: (vsim-7106) Use vsim option ‘-solvefailtestcase[=filename]’ to generate a simplified testcase that will reproduce the failure.
** Warning: (vsim-7084) No solutions exist which satisfy the specified constraints; randomize() failed.
