Random constraints
I found this implementation on a website and I’m trying to understand why they have made a comment saying that the constraint my_error is not a right way of implementation. I can understand that min and max don’t have a value associated with it compare with 0 and 128. But it produces result without any compilation error. Can someone explain?
class MyClass;
		rand bit [7:0] min, typ, max;
		// Valid expression
		constraint my_range { 0 < min;
		                      typ < max; typ > min;
		                      max < 128; }
		// Use of multiple operators in a single expression is not allowed
		constraint my_error { 0 < min < typ < max < 128; } // This will set min to 16 and randomize all others constraint my_min { min == 16; } // This will set max to a random value greater than or equal to 64 constraint my_max { max >= 64; }
In reply to nimitz_class:
The comment and explanation are not correct. It’s perfectly legal to write that code; it’s just that it does not produce results you think you should be getting.
This is a common beginner’s mistake. See Asking better questions on the Verification Academy Forums with EDAPlayground - Verification Horizons
