I have a protocol that writes in one cycle but takes two cycles to issue a read.
The code that notifies the transaction to the adapter is the following:
interface dbg_monitor_bfm
input logic clk_i,
input logic re_i,
input logic we_i,
input logic [DBG_ADDR_WIDTH-1:0] address_i,
input logic [DBG_DATA_WIDTH-1:0] write_data_i,
input logic [DBG_DATA_WIDTH-1:0] read_data_o
dbg_monitor proxy;
task run();
dbg_seq_item item;
dbg_seq_item cloned_item;
bit was_a_read;
was_a_read = 0;
forever begin
if (!was_a_read)
@(posedge clk_i);
else begin
was_a_read = 0;
if (dbg_we_i) begin
item = dbg_seq_item::type_id::create("item");
item.we = we_i;
item.re = 0;
item.addr = address_i;
item.data = write_data_i;
proxy.notify_transaction(item);
else if (dbg_re_i) begin
was_a_read = 1;
item.we = 0;
item.re = re_i;
@(posedge clk_i);
item.data = read_data_o;
endtask : run
endinterface : dbg_monitor_bfm
This works in the sense that it is capable of notifying the transaction but then the uvm_reg_map finishes later and does not take the correct value (that’s what I could see with the debugger). I think the main problem is that I have to wait for a cycle to get the read value from the registers but I do not know how to do it just in one cycle. I tried to adapt this code to work on the negative edge of re_i and we_i; Transactions were notified correctly but then the uvm_reg_map would wait until the next notified transaction after a lot of cycles (whenever there is a re_i or we_i negative edge).
So, do you think is it possible to do it in one cycle? Is there something that I am missing?
Thanks!!
Marc
