I created Register Model for DMA(direct memory access) and added HDL paths using add_hdl_path_slice for registers and add_hdl_path for the entire register model
The code is compiled free and when I do front door access using(WRITE and READ) methods it is happening but when I do Backdoor access(POKE and PEEK) I am not getting the output it is showing some errors as below.
UVM_ERROR /dv/p4Cusers01nd/dvcmin_noida_main_rc_xcelium_102020_180012_linux/uvm/src/uvm12ml/distrib/src/dpi/uvm_hdl_inca.c(568) @ 15: reporter [UVM/DPI/NOBJ2] name tbench_top.DUT.ctrl cannot be resolved to a hdl object (vlog,vhdl,vlog-slice)
UVM_ERROR /dv/p4Cusers01nd/dvcmin_noida_main_rc_xcelium_102020_180012_linux/uvm/src/uvm12ml/distrib/src/dpi/uvm_hdl_inca.c(568) @ 15: reporter [UVM/DPI/NOBJ2] name tbench_top.DUT.io_addr cannot be resolved to a hdl object (vlog,vhdl,vlog-slice)
UVM_ERROR /dv/p4Cusers01nd/dvcmin_noida_main_rc_xcelium_102020_180012_linux/uvm/src/uvm12ml/distrib/src/dpi/uvm_hdl_inca.c(568) @ 15: reporter [UVM/DPI/NOBJ2] name tbench_top.DUT.mem_addr cannot be resolved to a hdl object (vlog,vhdl,vlog-slice)
I am attaching the link to the code that i have written please check and help me out
LINK: Error
Thanks a lot in advance
Harshavardhan
