Dear Dave,
Please explain if the below code creates a write-write race condition for “y” :
initial
#5 y <= 2;
initial
y <= #5 3;
Observation : y always takes the value of 2 irrespective of the order of simulation .
Dear Dave,
initial
#5 y <= 2;
initial
y <= #5 3;
In reply to sush:
By definition in the 1800-2012 LRM section 10.4.2 Nonblocking procedural assignments, this is not a simulation race condition. The two assignment statements execute at different times. Even though they both schedule an update to y at time 5, the update to 3 is scheduled to happen before the update to 2. Last update wins.
Dear Dave,
I have tried the following code in Synopsys VCS compiler and could see race situation :
module test ;
reg [1:0]y;
initial
#5 y <= 2;
initial
y <= #5 3;
initial
#5 $strobe(“Value of y =%d”,y) ;
Observation : y takes 3 or 2 as per the order of simulation .
In reply to sush:
I’ve tried this example on Modelsim/Questa, and 3 other simulators and all preserve the ordering y = 2. You’ll need to report this to your tool vendor,
Thanks Dave .
Dear Dave,
I have one more query on race :
initial
{w,reset} = {1'b1,1'b1};
repeat(2)
@(negedge clock);
reset = 0;
#100 $finish ;
initial
#1 clock = 0;
forever #1 clock = ~clock ;
always@(negedge clock)
w = ~w ;
In the above snippet , I found the variable w doesn’t repeat with a value = 1 for 2 negedge cycles .It always toggles to 0 in the very first negedge of clock .
I have changed the order of simulation and found the same result .
It looks like repeat has no impact on w .
Could you please clarify the same ?
Susmita
In reply to sush:
I do not see how reset affects the value of w with the code you showed. Also note that if you declare clock as a reg, an X to 0 transition is considered a negedge.
Dear Dave,
I am not saying “reset” has an impact rather “repeat” construct should repeat value of w to 1 for 2 neg-edge of clock cycles .
{w,reset} = {1’b1,1’b1};
repeat(2)
@(negedge clock);
But the following snippet doesn’t repeat w to 1 for 2 negedge clock cycles rather in the first negedge i.e transition from x to 0 toggles initial value of w from 1 to 0.
w = ~w ;
In reply to sush:
Dear Dave,
initial
#5 y <= 2;
initial
y <= #5 3;
I see a race condition here! Which means incorrect usage of constructs.
For e.g. look at the code below,
//This is a race condition as you would agree.
initial
#5
y <= 2;
initial
#5;
y <= 3;
//Now only confusion could be of having an 'intra' assignment delay
//Which can be converted to simple delays(IEEE 1800-2012 Sec 9.4.5)
initial
#5
y <= 2;
initial
//y <= #5 3;
//Is same as
tempY = 3;
#5
y <= tempY;
In short any tool you use will give correct behavior(race/incorrect behavior) regardless.
In reply to MayurKubavat:
There is no race. Your conversion to remove the intra-assignment delay is not equivalent to the original code and yours does have a race. The LRM section I mention above states that if the ordering of the assignments is determinate, the outcome is determinate.
In reply to sush:
Please start a new topic thread if you ate still having issues. It will help if you can provide a complete runnable example along with expected versus actual results. As you have written, I do not understand your issue.
