Thanks a lot, Dev for the reply. Let me quote the exact cover group code and trigger event which I am using in my TB :
The bin I am concerned about is below, present inside the first cover point named cp_PG_EXIT_CASES i.e.
wildcard bins P1_2_SIDEBAND_CONFIG_BIT9_LANE_RESET_GEN1
wildcard bins P1_2_SIDEBAND_CONFIG_BIT9_LANE_RESET_GEN2
wildcard bins P1_2_SIDEBAND_CONFIG_BIT9_LANE_RESET_GEN3
wildcard bins P1_2_SIDEBAND_CONFIG_BIT9_LANE_RESET_GEN4
**And here for the concerned bins which I have written above, I can see on the waveform, no other signal (present inside vector sample1 or sample2 i.e. the signals on which covergroup triggers) is changing in b/w change of signals on which the transition bin is written. Thus it also rules out any possibility of false coverage or miss-sampling or something.
covergroup pg_exit_cg(string name) with function sample (int en, logic[18:0] sample1, logic [16:0] sample2);
option.per_instance = 1;
option.name = name;
type_option.strobe = 1;
cp_PG_EXIT_CASES : coverpoint sample1 iff (en && m_ctrl_vif.pipe_laneX_protocol==0) {
wildcard bins P1_2_MPLLA_FORCE_EN_GEN3 = ({19’b1100_00_??1_0_0_0010_1_1_00}=>{19’b1100_00??1_1_0_0010_1?00}=>{19’b1100_00??1_1_0_0010_1_0_00});
wildcard bins P1_2_SIDEBAND_MPLLA_FORCE_EN_GEN3 = ({19’b0100_11??1_0_0_0010_1_1_00}=>{19’b0100_11??1_1_0_0010_1?00}=>{19’b0100_11??1_1_0_0010_1_0_00});
wildcard bins P2_NOBEACON_MPLLA_FORCE_EN_GEN3 = ({19’b1111_00??1_0_0_0010_1_1_00}=>{19’b1111_00??1_1_0_0010_1?00}=>{19’b1111_00??1_1_0_0010_1_0_00});
wildcard bins P1_2_MPLLA_FORCE_EN_GEN4 = ({19’b1100_00??1_0_0_0011_1_1_00}=>{19’b1100_00??1_1_0_0011_1?00}=>{19’b1100_00??1_1_0_0011_1_0_00});
wildcard bins P1_2_SIDEBAND_MPLLA_FORCE_EN_GEN4 = ({19’b0100_11??1_0_0_0011_1_1_00}=>{19’b0100_11??1_1_0_0011_1?00}=>{19’b0100_11??1_1_0_0011_1_0_00});
wildcard bins P2_NOBEACON_MPLLA_FORCE_EN_GEN4 = ({19’b1111_00??1_0_0_0011_1_1_00}=>{19’b1111_00??1_1_0_0011_1?00}=>{19’b1111_00??_1_1_0_0011_1_0_00});
wildcard bins P1_2_MPLLB_FORCE_EN_GEN1 = ({19'b1100_00_?_?_1_0_0_0000_1_1_00}=>{19'b1100_00_?_?_1_0_1_0000_1_?_00}=>{19'b1100_00_?_?_1_0_1_0000_1_0_00});
wildcard bins P1_2_SIDEBAND_MPLLB_FORCE_EN_GEN1 = ({19’b0100_11_??1_0_0_0000_1_1_00}=>{19’b0100_11??1_0_1_0000_1?00}=>{19’b0100_11??1_0_1_0000_1_0_00});
wildcard bins P2_NOBEACON_MPLLB_FORCE_EN_GEN1 = ({19’b1111_00??1_0_0_0000_1_1_00}=>{19’b1111_00??1_0_1_0000_1?00}=>{19’b1111_00??1_0_1_0000_1_0_00});
wildcard bins P1_2_MPLLB_FORCE_EN_GEN2 = ({19’b1100_00??1_0_0_0001_1_1_00}=>{19’b1100_00??1_0_1_0001_1?00}=>{19’b1100_00??1_0_1_0001_1_0_00});
wildcard bins P1_2_SIDEBAND_MPLLB_FORCE_EN_GEN2 = ({19’b0100_11??1_0_0_0001_1_1_00}=>{19’b0100_11??1_0_1_0001_1?00}=>{19’b0100_11??1_0_1_0001_1_0_00});
wildcard bins P2_NOBEACON_MPLLB_FORCE_EN_GEN2 = ({19’b1111_00??1_0_0_0001_1_1_00}=>{19’b1111_00??1_0_1_0001_1?00}=>{19’b1111_00?_?_1_0_1_0001_1_0_00});
wildcard bins P1_2_CONFIG_BIT9_LANE_RESET_GEN1 = ({19'b1100_00_0_?_1_0_0_0000_1_1_00}=>{19'b1100_00_0_?_0_0_0_0000_1_?_00}=>{19'b1100_00_0_?_0_0_0_0000_1_0_00});
wildcard bins P1_2_CONFIG_BIT6_PG_MODE_GEN1 = ({19'b1100_00_?_0_1_0_0_0000_1_1_00}=>{19'b1100_00_?_0_1_0_0_0000_0_?_00}=>{19'b1100_00_?_0_1_0_0_0000_0_0_00});
wildcard bins P1_2_MAXPCLK_REQ_CHANGE_TO_01_GEN1 = ({19'b1100_00_?_?_1_0_0_0000_1_1_00}=>{19'b1100_00_?_?_1_0_0_0000_1_?_01}=>{19'b1100_00_?_?_1_0_0_0000_1_0_01});
wildcard bins P1_2_MAXPCLK_REQ_CHANGE_TO_11_GEN1 = ({19'b1100_00_?_?_1_0_0_0000_1_1_00}=>{19'b1100_00_?_?_1_0_0_0000_1_?_11}=>{19'b1100_00_?_?_1_0_0_0000_1_0_11});
wildcard bins P1_2_SIDEBAND_CONFIG_BIT9_LANE_RESET_GEN1 = ({19'b0100_11_0_?_1_0_0_0000_1_1_00}=>{19'b0100_00_0_?_0_0_0_0000_1_1_00}=>{19'b0100_00_0_?_0_0_0_0000_1_0_00}); // Race
wildcard bins P1_2_SIDEBAND_CONFIG_BIT6_PG_MODE_GEN1 = ({19'b0100_11_?_0_1_0_0_0000_1_1_00}=>{19'b0100_11_?_0_1_0_0_0000_0_?_00}=>{19'b0100_11_?_0_1_0_0_0000_0_0_00});
wildcard bins P1_2_SIDEBAND_MAXPCLK_REQ_CHANGE_TO_01_GEN1 = ({19'b0100_11_?_?_1_0_0_0000_1_1_00}=>{19'b0100_11_?_?_1_0_0_0000_1_?_01}=>{19'b0100_00_?_?_1_0_0_0000_1_0_01}); // Race
wildcard bins P1_2_SIDEBAND_MAXPCLK_REQ_CHANGE_TO_11_GEN1 = ({19'b0100_11_?_?_1_0_0_0000_1_1_00}=>{19'b0100_11_?_?_1_0_0_0000_1_?_11}=>{19'b0100_11_?_?_1_0_0_0000_1_0_11});
wildcard bins P2_NOBEACON_CONFIG_BIT9_LANE_RESET_GEN1 = ({19'b1111_00_0_?_1_0_0_0000_1_1_00}=>{19'b1111_00_0_?_0_0_0_0000_1_?_00}=>{19'b1111_00_0_?_0_0_0_0000_1_0_00});
wildcard bins P2_NOBEACON_CONFIG_BIT6_PG_MODE_GEN1 = ({19'b1111_00_?_0_1_0_0_0000_1_1_00}=>{19'b1111_00_?_0_1_0_0_0000_0_?_00}=>{19'b1111_00_?_0_1_0_0_0000_0_0_00});
wildcard bins P2_NOBEACON_MAXPCLK_REQ_CHANGE_TO_01_GEN1 = ({19'b1111_00_?_?_1_0_0_0000_1_1_00}=>{19'b1111_00_?_?_1_0_0_0000_1_?_01}=>{19'b1111_00_?_?_1_0_0_0000_1_0_01});
wildcard bins P2_NOBEACON_MAXPCLK_REQ_CHANGE_TO_11_GEN1 = ({19'b1111_00_?_?_1_0_0_0000_1_1_00}=>{19'b1111_00_?_?_1_0_0_0000_1_?_11}=>{19'b1111_00_?_?_1_0_0_0000_1_0_11});
wildcard bins P1_2_CONFIG_BIT9_LANE_RESET_GEN2 = ({19'b1100_00_0_?_1_0_0_0001_1_1_00}=>{19'b1100_00_0_?_0_0_0_0001_1_?_00}=>{19'b1100_00_0_?_0_0_0_0001_1_0_00});
wildcard bins P1_2_CONFIG_BIT6_PG_MODE_GEN2 = ({19'b1100_00_?_0_1_0_0_0001_1_1_00}=>{19'b1100_00_?_0_1_0_0_0001_0_?_00}=>{19'b1100_00_?_0_1_0_0_0001_0_0_00});
wildcard bins P1_2_MAXPCLK_REQ_CHANGE_TO_01_GEN2 = ({19'b1100_00_?_?_1_0_0_0001_1_1_00}=>{19'b1100_00_?_?_1_0_0_0001_1_?_01}=>{19'b1100_00_?_?_1_0_0_0001_1_0_01});
wildcard bins P1_2_MAXPCLK_REQ_CHANGE_TO_11_GEN2 = ({19'b1100_00_?_?_1_0_0_0001_1_1_00}=>{19'b1100_00_?_?_1_0_0_0001_1_?_11}=>{19'b1100_00_?_?_1_0_0_0001_1_0_11});
wildcard bins P1_2_SIDEBAND_CONFIG_BIT9_LANE_RESET_GEN2 = ({19’b0100_11_0_?1_0_0_0001_1_1_00}=>{19’b0100_00_0?0_0_0_0001_1_1_00}=>{19’b0100_00_0?0_0_0_0001_1_0_00}); // Race
wildcard bins P1_2_SIDEBAND_CONFIG_BIT6_PG_MODE_GEN2 = ({19’b0100_11?0_1_0_0_0001_1_1_00}=>{19’b0100_11?0_1_0_0_0001_0?00}=>{19’b0100_11?0_1_0_0_0001_0_0_00});
wildcard bins P1_2_SIDEBAND_MAXPCLK_REQ_CHANGE_TO_01_GEN2 = ({19’b0100_11??1_0_0_0001_1_1_00}=>{19’b0100_11??1_0_0_0001_1_1_01}=>{19’b0100_00??1_0_0_0001_1_0_01}); // Race
wildcard bins P1_2_SIDEBAND_MAXPCLK_REQ_CHANGE_TO_11_GEN2 = ({19’b0100_11??1_0_0_0001_1_1_00}=>{19’b0100_11??1_0_0_0001_1?11}=>{19’b0100_11??1_0_0_0001_1_0_11});
wildcard bins P2_NOBEACON_CONFIG_BIT9_LANE_RESET_GEN2 = ({19’b1111_00_0?1_0_0_0001_1_1_00}=>{19’b1111_00_0?0_0_0_0001_1?00}=>{19’b1111_00_0?0_0_0_0001_1_0_00});
wildcard bins P2_NOBEACON_CONFIG_BIT6_PG_MODE_GEN2 = ({19’b1111_00?0_1_0_0_0001_1_1_00}=>{19’b1111_00?0_1_0_0_0001_0?00}=>{19’b1111_00?0_1_0_0_0001_0_0_00});
wildcard bins P2_NOBEACON_MAXPCLK_REQ_CHANGE_TO_01_GEN2 = ({19’b1111_00??1_0_0_0001_1_1_00}=>{19’b1111_00??1_0_0_0001_1?01}=>{19’b1111_00??1_0_0_0001_1_0_01});
wildcard bins P2_NOBEACON_MAXPCLK_REQ_CHANGE_TO_11_GEN2 = ({19’b1111_00??1_0_0_0001_1_1_00}=>{19’b1111_00??1_0_0_0001_1?11}=>{19’b1111_00??_1_0_0_0001_1_0_11});
wildcard bins P1_2_CONFIG_BIT9_LANE_RESET_GEN3 = ({19'b1100_00_0_?_1_0_0_0010_1_1_00}=>{19'b1100_00_0_?_0_0_0_0010_1_?_00}=>{19'b1100_00_0_?_0_0_0_0010_1_0_00});
wildcard bins P1_2_CONFIG_BIT6_PG_MODE_GEN3 = ({19'b1100_00_?_0_1_0_0_0010_1_1_00}=>{19'b1100_00_?_0_1_0_0_0010_0_?_00}=>{19'b1100_00_?_0_1_0_0_0010_0_0_00});
wildcard bins P1_2_MAXPCLK_REQ_CHANGE_TO_01_GEN3 = ({19'b1100_00_?_?_1_0_0_0010_1_1_00}=>{19'b1100_00_?_?_1_0_0_0010_1_?_01}=>{19'b1100_00_?_?_1_0_0_0010_1_0_01});
wildcard bins P1_2_MAXPCLK_REQ_CHANGE_TO_11_GEN3 = ({19'b1100_00_?_?_1_0_0_0010_1_1_00}=>{19'b1100_00_?_?_1_0_0_0010_1_?_11}=>{19'b1100_00_?_?_1_0_0_0010_1_0_11});
wildcard bins P1_2_SIDEBAND_CONFIG_BIT9_LANE_RESET_GEN3 = ({19'b0100_11_0_?_1_0_0_0010_1_1_00}=>{19'b0100_00_0_?_0_0_0_0010_1_?_00}=>{19'b0100_00_0_?_0_0_0_0010_1_0_00}); // Race
wildcard bins P1_2_SIDEBAND_CONFIG_BIT6_PG_MODE_GEN3 = ({19'b0100_11_?_0_1_0_0_0010_1_1_00}=>{19'b0100_11_?_0_1_0_0_0010_0_?_00}=>{19'b0100_11_?_0_1_0_0_0010_0_0_00});
wildcard bins P1_2_SIDEBAND_MAXPCLK_REQ_CHANGE_TO_01_GEN3 = ({19'b0100_11_?_?_1_0_0_0010_1_1_00}=>{19'b0100_11_?_?_1_0_0_0010_1_?_01}=>{19'b0100_00_?_?_1_0_0_0010_1_0_01}); // Race
wildcard bins P1_2_SIDEBAND_MAXPCLK_REQ_CHANGE_TO_11_GEN3 = ({19'b0100_11_?_?_1_0_0_0010_1_1_00}=>{19'b0100_11_?_?_1_0_0_0010_1_?_11}=>{19'b0100_11_?_?_1_0_0_0010_1_0_11});
wildcard bins P2_NOBEACON_CONFIG_BIT9_LANE_RESET_GEN3 = ({19'b1111_00_0_?_1_0_0_0010_1_1_00}=>{19'b1111_00_0_?_0_0_0_0010_1_?_00}=>{19'b1111_00_0_?_0_0_0_0010_1_0_00});
wildcard bins P2_NOBEACON_CONFIG_BIT6_PG_MODE_GEN3 = ({19'b1111_00_?_0_1_0_0_0010_1_1_00}=>{19'b1111_00_?_0_1_0_0_0010_0_?_00}=>{19'b1111_00_?_0_1_0_0_0010_0_0_00});
wildcard bins P2_NOBEACON_MAXPCLK_REQ_CHANGE_TO_01_GEN3 = ({19'b1111_00_?_?_1_0_0_0010_1_1_00}=>{19'b1111_00_?_?_1_0_0_0010_1_?_01}=>{19'b1111_00_?_?_1_0_0_0010_1_0_01});
wildcard bins P2_NOBEACON_MAXPCLK_REQ_CHANGE_TO_11_GEN3 = ({19'b1111_00_?_?_1_0_0_0010_1_1_00}=>{19'b1111_00_?_?_1_0_0_0010_1_?_11}=>{19'b1111_00_?_?_1_0_0_0010_1_0_11});
wildcard bins P1_2_CONFIG_BIT9_LANE_RESET_GEN4 = ({19'b1100_00_0_?_1_0_0_0011_1_1_00}=>{19'b1100_00_0_?_0_0_0_0011_1_?_00}=>{19'b1100_00_0_?_0_0_0_0011_1_0_00});
wildcard bins P1_2_CONFIG_BIT6_PG_MODE_GEN4 = ({19'b1100_00_?_0_1_0_0_0011_1_1_00}=>{19'b1100_00_?_0_1_0_0_0011_0_?_00}=>{19'b1100_00_?_0_1_0_0_0011_0_0_00});
wildcard bins P1_2_MAXPCLK_REQ_CHANGE_TO_01_GEN4 = ({19'b1100_00_?_?_1_0_0_0011_1_1_00}=>{19'b1100_00_?_?_1_0_0_0011_1_?_01}=>{19'b1100_00_?_?_1_0_0_0011_1_0_01});
wildcard bins P1_2_MAXPCLK_REQ_CHANGE_TO_11_GEN4 = ({19'b1100_00_?_?_1_0_0_0011_1_1_00}=>{19'b1100_00_?_?_1_0_0_0011_1_?_11}=>{19'b1100_00_?_?_1_0_0_0011_1_0_11});
wildcard bins P1_2_SIDEBAND_CONFIG_BIT9_LANE_RESET_GEN4 = ({19'b0100_11_0_?_1_0_0_0011_1_1_00}=>{19'b0100_00_0_?_0_0_0_0011_1_?_00}=>{19'b0100_00_0_?_0_0_0_0011_1_0_00}); // Race
wildcard bins P1_2_SIDEBAND_CONFIG_BIT6_PG_MODE_GEN4 = ({19'b0100_11_?_0_1_0_0_0011_1_1_00}=>{19'b0100_11_?_0_1_0_0_0011_0_?_00}=>{19'b0100_11_?_0_1_0_0_0011_0_0_00});
wildcard bins P1_2_SIDEBAND_MAXPCLK_REQ_CHANGE_TO_01_GEN4 = ({19'b0100_11_?_?_1_0_0_0011_1_1_00}=>{19'b0100_11_?_?_1_0_0_0011_1_?_01}=>{19'b0100_00_?_?_1_0_0_0011_1_0_01}); // Race
wildcard bins P1_2_SIDEBAND_MAXPCLK_REQ_CHANGE_TO_11_GEN4 = ({19'b0100_11_?_?_1_0_0_0011_1_1_00}=>{19'b0100_11_?_?_1_0_0_0011_1_?_11}=>{19'b0100_11_?_?_1_0_0_0011_1_0_11});
wildcard bins P2_NOBEACON_CONFIG_BIT9_LANE_RESET_GEN4 = ({19'b1111_00_0_?_1_0_0_0011_1_1_00}=>{19'b1111_00_0_?_0_0_0_0011_1_?_00}=>{19'b1111_00_0_?_0_0_0_0011_1_0_00});
wildcard bins P2_NOBEACON_CONFIG_BIT6_PG_MODE_GEN4 = ({19'b1111_00_?_0_1_0_0_0011_1_1_00}=>{19'b1111_00_?_0_1_0_0_0011_0_?_00}=>{19'b1111_00_?_0_1_0_0_0011_0_0_00});
wildcard bins P2_NOBEACON_MAXPCLK_REQ_CHANGE_TO_01_GEN4 = ({19'b1111_00_?_?_1_0_0_0011_1_1_00}=>{19'b1111_00_?_?_1_0_0_0011_1_?_01}=>{19'b1111_00_?_?_1_0_0_0011_1_0_01});
wildcard bins P2_NOBEACON_MAXPCLK_REQ_CHANGE_TO_11_GEN4 = ({19'b1111_00_?_?_1_0_0_0011_1_1_00}=>{19'b1111_00_?_?_1_0_0_0011_1_?_11}=>{19'b1111_00_?_?_1_0_0_0011_1_0_11});
cp_LANE_DISABLE : coverpoint sample2 iff (en && m_ctrl_vif.pipe_laneX_protocol==0) {
wildcard bins LANE_ENABLE = {17’b0_???};
wildcard bins LANE_DISABLE_PCLK_GATED = {17’b1_???0};
wildcard bins LANE_DISABLE_PCLK_ON = {17’b1_???1};
macros being used for sampling the covergroup**
define EVENT_pg_exit_cg (m_ctrl_vif.pipe_laneX_powerdown_skewed, m_chip_vif.phy_mplla_force_en, m_chip_vif.phy_mpllb_force_en, m_ctrl_vif.pipe_laneX_reset_n_skewed, m_ctrl_vif.pipe_rxX_disable, m_chip_vif.upcs_pipe_config, m_ctrl_vif.pipe_txX_disable, m_chip_vif.pg_mode_en, m_ctrl_vif.pipe_laneX_maxpclkreq, m_txrx_vif.pipe_txX_compliance, m_txrx_vif.pipe_txX_elecidle,m_ctrl_vif.pipe_laneX_rate_skewed, m_ctrl_vif.pg_reset)
define SAMP_EVENT_pg_exit_cg 1,.sample1({m_ctrl_vif.pipe_laneX_powerdown_skewed,m_ctrl_vif.pipe_txX_disable,m_ctrl_vif.pipe_rxX_disable,m_chip_vif.upcs_pipe_config[9],m_chip_vif.upcs_pipe_config[6],m_ctrl_vif.pipe_laneX_reset_n_skewed,m_chip_vif.phy_mplla_force_en,m_chip_vif.phy_mpllb_force_en,m_ctrl_vif.pipe_laneX_rate_skewed,m_chip_vif.pg_mode_en,m_ctrl_vif.pg_reset,m_ctrl_vif.pipe_laneX_maxpclkreq}), .sample2({m_txrx_vif.pipe_txX_elecidle&m_txrx_vif.pipe_txX_compliance,m_chip_vif.upcs_pipe_config})
sampling of covergroup**
– This below forever loop is present inside the run_phase task of some monitor files And this m_lane_cg is the object of the file in which coverage is implemented.
forever begin
@(EVENT_pg_exit_cg) m_lane_cg.pg_exit_cg.sample(
SAMP_EVENT_pg_exit_cg);
I hope this helps you to answer the query.
Regards
Abhinay
