Hi ,
While trying to learn via trying out different stuff related to phases and TLM , I ended up coding the following .
class componentA extends uvm_component;
`uvm_component_utils (componentA)
uvm_blocking_put_port #(int) m_put_port;
uvm_tlm_fifo #(int) m_fifo_export;
uvm_blocking_put_imp #(int,componentA) m_put_imp;
function new (string name = "componentA", uvm_component parent= null);
super.new (name, parent);
virtual function void build_phase (uvm_phase phase);
// super.build_phase (phase) ; // Learnt recently here !!
m_put_port = new("m_put_port", this,1,2); // By default max_size is 1 so we would get an Error since we want it to connect to export as well as imp !!
m_fifo_export = new("m_fifo_export", this ,0); // 0 indicates Unbounded , so can store infinite elements
m_put_imp = new("m_put_imp", this);
virtual function void connect_phase (uvm_phase phase);
m_put_port.connect(m_fifo_export.put_export);
m_put_port.connect(m_put_imp);
virtual task run_phase (uvm_phase phase);
phase.raise_objection(this `ifdef M2 ,,2 `endif );
for ( int i = 1 ; i < 6 ; i++ )
m_put_port.put(i);
`uvm_info ("COMPA", " All put Done ", UVM_LOW)
phase.drop_objection(this`ifdef M2 ,,1 `endif);
virtual task main_phase (uvm_phase phase);
int ii ;
phase.raise_objection(this);
while ( m_fifo_export.is_empty() != 1 ) // is_empty() returns 1 when empty , so we fetch till Not Empty
m_fifo_export.get(ii);
`uvm_info ("GET_PEEK_EXPORT", $sformatf(" Got %0d ",ii), UVM_LOW)
# 2 ;
phase.drop_objection(this `ifdef M2 ,,2 `endif );
task put ( int INT ) ;
`uvm_info ("PUT_IMP", $sformatf(" Got %0d ",INT), UVM_LOW)
// Inside module
componentA compA ;
compA = new("compA",null);
run_test();
I get following Output [ Without +define+M2 ] ::
UVM_INFO @ 0: reporter [RNTST] Running test …
UVM_INFO EX.sv(56) @ 0: compA [COMPA] All put Done
UVM_INFO /asiclibs/libraries/uvm/uvm-1.1d/src/base/uvm_objection.svh(1267) @ 0: reporter [TEST_DONE] ‘run’ phase is ready to proceed to the ‘extract’ phase
UVM_INFO EX.sv(71) @ 0: compA [GET_PEEK_EXPORT] Got 1
UVM_INFO EX.sv(71) @ 2: compA [GET_PEEK_EXPORT] Got 2
UVM_INFO EX.sv(71) @ 4: compA [GET_PEEK_EXPORT] Got 3
UVM_INFO EX.sv(71) @ 6: compA [GET_PEEK_EXPORT] Got 4
UVM_INFO EX.sv(71) @ 8: compA [GET_PEEK_EXPORT] Got 5
[Q1] I am confused how I get msg from reporter before all the get() calls ? .
Is it cos the run_phase() objection Count is 0 ? in that case then how do I still manage to get displays from get() call ?
[Q2] I know that run_phase() executes in parallel to main_phase() , so in this code will both objections be raised at Time 0 ?
With +define+M2 , I get an Error ::
UVM_FATAL @ 10: main_objection [OBJTN_ZERO] Object “compA” attempted to drop objection ‘main_objection’ count below zero
[Q3] Would it make a difference if put() is done in main_phase while get() is done in run_phase ?
[Q4] Why the error ? Won’t the raise and drop objections in run_phase and main_phase be additive ? I raised 2 objections in run_phase while dropping only 1 . Since I raise 1 again in main_phase ( total 2 ) , I drop 2 objections in main_phase
[Q5] I notice that I don’t get the previous message in this case ( reporter [TEST_DONE] ‘run’ phase is ready to proceed to the ‘extract’ phase ) , why so ?
[Q6] Why no output from task put() ? Does it have to do with set_if() && get_if() of uvm_port_base class ?
