In reply to MICRO_91:
- Your problems stem from the fact that there are no delays in the run_phase between the raise and drop. The run_phase is over at time 0 and ready to proceed, but the extract_phase won’t begin until the main phase ends.
- There’s a requirement that there must be some blocking delay between the raise and drop. Otherwise you get this kind of error message.
- We recommend just using the run_phase which avoids many issues including the ones you see here.
- Same as Q2
- Same as Q2
- Sorry, uncharted territory.
