My question is client will send one request to memory, memory has to send response back to client with in 1000 cycles. I have to write a check in such a way that if memory will take more than 1000 cycles I have to rise timeout flag. My doubt is I need to write an assertion or scoreboard check for this kind of checking. I think in assertions it is comparatively easy if I want to write a check in scoreboard I dont have any idea how to proceed further can any one help for this checker.
In reply to marathuteja:
Your question seems to be: How do I write an equivalent concurrent SVA assertion in a scoreboard that is a class. Concurrent assertions are illegal in classes.
I explain this concept in my paper Understanding the SVA Engine Using the Fork-Join Model Verification Horizons Using a model, the paper addresses important concepts about attempts and threads. Emphasizes the total independence of attempts.
I came up with a quickly tested model of your requirements using SVA and a class.
For simplicity, I embedded the class into the module so as to quickly have access to the module variables, and without having to go thru a virtual interface. The latency can be changed to 1000, but for this test, I set it to 5 for simplicity
Edit code - EDA Playground // code
EPWave Waveform Viewer // wave
/* My question is client will send one request to memory,
how to proceed further can any one help for this checker. */
module my_module;
bit clk, req, rdy, acq_flag;
int pass, fail, latency=5; // 5 instead of 1000 for this test.
class c;
task scoreb();
forever
if (req==1) test();
else @(posedge clk);
task test();
int v=latency;
while (v>=0) begin
@(posedge clk) v=v-1;
if(rdy || v<0) break;
@(posedge clk) assert((acq_flag==1 && v<0) || (acq_flag==0 && v >=0))
pass=pass+8; else fail=fail+8; ;
property p_req_rdy;
int v_count;
@(posedge clk) ($rose(req), v_count=latency) |=>
(1, v_count=v_count-1)[*1:$] ##0 ((v_count < 0) || rdy)
## 1 (acq_flag && v_count<0) || (!acq_flag && v_count>=0);
ap_req_rdy: assert property(p_req_rdy) pass=pass+1; else fail=fail+1;
c c1=new();
initial c1.scoreb();
initial forever #1 clk = !clk;
$dumpfile("dump.vcd"); $dumpvars;
#2 @(posedge clk) req <= 1; @(posedge clk) req<=0;
repeat(2) @(posedge clk); rdy <=1; @(posedge clk) rdy <= 0;
#2 $finish;
Ben@systemverilog.us
or Cohen_Links_to_papers_books - Google Docs
property mem_write;
@(posedge clk)
$rose(req) |=> strong(mem_ack[=1] intersect 1[*1:100]);
endprperty
@nitin62goel
Any reason you have used 1[*1:100] in your consequent ?
On changing your RHS sequence to 1[*1000]
property mem_write;
@(posedge clk) $rose(req) |=> strong(mem_ack[=1] intersect 1[*1000]);
This meets the requirement that mem_ack should be asserted within 1000 clocks
The assertion would fail in the following scenarios ::
(1) mem_ack isn’t asserted even once within 1000 clocks
(2) mem_ack is asserted more than once ( non-consecutive / consecutive ) within 1000 clocks
(3) Simulation ends before 1000 clocks with mem_ack asserted once or without any mem_ack asserted
However the original requirement is
Client will send one request to memory, memory has to send response back to client
within 1000 cycle.If memory will take more than 1000 cycles I have to rise timeout flag
Hence the following scenario is valid :: ‘mem_ack’ isn’t asserted within 1000 clocks
