Write a timeout detection check to flag an error if “status ok” is not asserted with in 1microsecond of asserting “start”. using fork not with assertion can any one help me how to write a fork block for this check.
In reply to marathuteja:
Something like this maybe ?
module test();
int start = 1;
int status;
bit timeout_flag = 0;
wait(start==1) ;
fork begin //isolator
wait(status == 1) ; //wait for status ok
#1us;
timeout_flag = 1;
join_any;
if(timeout_flag == 1)
$display("Fail");
disable fork;
end join //isolator
In reply to KillSteal:
KillSteal has a good start, but I prefer the approach I used in my paper
**Understanding the SVA Engine Using the Fork-Join Model
** Verification Horizons
Using a model, the paper addresses important concepts about attempts and threads. Emphasizes the total independence of attempts.
Note that for every posedge of start I trigger the automatic task check_ok.
This is just like a concurrent assertion where at every clocking event you trigger the property.
Edit code - EDA Playground // code
EPWave Waveform Viewer // wave
I modified the units of time for demo use.
// Write a timeout detection check to flag an error if "status ok" is not asserted
// within 1microsecond of asserting "start". using fork not with assertion can any
// one help me how to write a fork block for this check.
module test();
typedef enum {IDLE, OK} status_e; //
//status_e status;
int status=0;
bit start, started;
int pass, fail;
always @(posedge start)
fork check_ok(); // trigger the task
join_none
task automatic check_ok();
bit timeout_flag=0;
started=1; // debug
fork begin
// if(status == 0) @(posedge status) pass=1; //wait for status ok
wait(status==1); // above works too
#15;
timeout_flag = 1;
join_any;
am_stat_ok: assert(timeout_flag == 0) pass=pass+1;
else begin fail=fail+1; $display("Fail"); end
//disable fork;
end join //isolator
$dumpfile("dump.vcd"); $dumpvars;
status=0; //IDLE;
#10 start=1;
#3 status=1;
#30 status=0;
#3 $finish;
Ben@systemverilog.us
or Cohen_Links_to_papers_books - Google Docs
