In reply to hemum_p:
Note that in this forum we do NOT address specific tools, but rather the language and its application. Thus, my response is targeted to the language and style.
from 1800,
sequence_declaration ::=
sequence sequence_identifier [ ( [ sequence_port_list ] ) ] ;
sequence_port_list ::=
sequence_port_item {, sequence_port_item}
sequence_port_item ::=
{ attribute_instance } [ local [ sequence_lvar_port_direction ] ] sequence_formal_type
formal_port_identifier {variable_dimension} [ = sequence_actual_arg ]
sequence_lvar_port_direction ::= input | inout | output
16.8.2 Local variable formal arguments in sequence declarations
A formal argument of a named sequence may be designated as a local variable argument by specifying the keyword local in the port item, followed optionally by one of the directions input, inout, or output. If no direction is specified explicitly, then the direction input shall be inferred.
Thus, to use use the direction input, you also need local. The following compiles OK in the compiler I have:
sequence seq_send_byte (local logic s_data, local input logic [7:0] data_to_send);
endsequence
// But do you want the argument to be local?
// can this work for you?
sequence seq_send_byte (logic s_data, logic [7:0] data_to_send);
s_data == data_to_send[0] ##1
s_data == data_to_send[1] ##1
s_data == data_to_send[2] ##1
s_data == data_to_send[3] ##1
s_data == data_to_send[4] ##1
s_data == data_to_send[5] ##1
s_data == data_to_send[6] ##1
s_data == data_to_send[7] ;
endsequence
// A more compact and generic approach to write the above is:
sequence seq_send_byte2 (logic s_data, logic [7:0] data_to_send);
int v=0;
(s_data == data_to_send[v], v=v+1'b1)[*8] ;
endsequence
