Push_pull, open drain in verilog
In reply to Dhee_27:
Here’s a good explanation about the concepts.
Push/Pull is the normal mode of most gate outputs - drive a zero or one. Open-drain can drive a zero or high-Z. In Verilog, this can be done with a continuous assignment.
assign push_pull = data_reg;     // implicit
assign (strong0, strong1) push_pull = data_reg; // explicit
assign (strong0, highz1) open_drain = data_reg;
If this needs to be programmable, you can use a mode bit.
assign bus = mode ? push_pull : open_drain;
assign (pull1,highz0) = 1; // pull-up
