Procedural concurrent assertions within for loop
Hi All,
LRM 2017 Section 16.14.6.1 mentions ::
// Assume for this example that (posedge clk) will not occur at time 0
always @(posedge clk) begin
int i = 10; // My Comment :: Incorrect , should be explicitly declared as static OR automatic here
 for (i=0; i<10; i++) begin
  a1: assert property (foo[i] && bar[i]); // My Comment :: Infers leading clock as @(posedge clk)
In any given clock cycle, each of these assertions will result in 10 queued executions.
Every execution of assertion a1, however, will be checking the value of (foo[10] && bar[10]) ,
since the sampled value of i will always be 10, its final value from the previous execution of the procedure
I have a few questions related to it
[Q1] I am not clear on the last line ::
Every execution of assertion a1, however, will be checking the value of (foo[10] && bar[10]),since the sampled value of i will always be 10
Why doesn’t it result in :: (foo[0] && bar[0]) , (foo[1] && bar[1]) , … (foo[9] && bar[9]) ?
My intuition is that the unlooping of for-loop would occur in Active region
whereas the concurrent assertion gets evaluated in Observed region.
Would the value of ‘i’ be 10 in Observed region ?
[Q2] Assume that variables ‘foo’ , ‘bar’ are declared as
logic [9:0] foo , bar ; // 10-bit wide
Essentially foo[10] , bar[10] are invalid indexes.
So won’t (foo[10] && bar[10]) result in ( 1’bX && 1’bX ) i.e 1’bX i.e False ?
[Q3] What if the assumption is not true i.e posedge of clk occurs at time 0 ? What difference would it make ?
[Q4] I want to add a fail action block to ‘a1’ that displays the index ( i.e ‘i’ ) for which the failure occurs. What would the correct way be ?
  for ( int i=0; i<10; i++) begin // 'i' is now automatic
  //  Will the following approach work ?
  a1: assert property (foo[i] && bar[i]) else $display("Failure for foo[%0d] is %1b, bar[%0d] is %1b",$sampled(i),foo[$sampled(i)],$sampled(i),bar[$sampled(i)]);
Blockquote
Blockquote
// When using a **const cast**, the value of the expression is treated as if it
// were defined as a constant variable of the same type.
const'(j) // treats the loop iterator j as a constant within the loop.
    // variable declared outside for statement is static (see 6.21)
   int i; // i is a static variable; it retains its LAST value at the end of the loop
     a2: assert property (foo[const'(i)] && bar[i]);
     a3: assert property (foo[const'(i)] && bar[const'(i)]);
// Because of the loop, the simulator will produce for each assertion statement 10 assertions. Something like:
   int i; // static local variable
  for (i=0; i<10; i++) begin ; end // sets the value of i
                            // nothing else
   a1_0: assert property (foo[i] && bar[i]);
  a1_9 : assert property (foo[i] && bar[i]);
  a2_0: assert property (foo[0] && bar[i]);
   a2_9: assert property (foo[9] && bar[i]);
   a3_0: assert property (foo[0] && bar[0]);
  a3_9: assert property (foo[9] && bar[9]);
// In the very 1st (posedge clk), i==0 (its default value).
// After the 1st (posedge clk), i-==10 (the last iteration)
// At (posedge clk) clocking event , the simulator sees 30 assertions
//  At the clocking event , the simulation samples the  values foo[i],  bar[i]
// using the sampled value of "i" (i==0 at init, i==10 after processing of 1st posedge clk).  This explains why
a1_9 : assert property (foo[i] && bar[i]); // is same as
a1_9 : assert property (foo[0] && bar[0]); // in the 1st clocking event
a1_9 : assert property (foo[10] && bar[10]); // after the 1st cycle
Because of no delay (either #1; or clk cycle delay) located in the fir loop which leads to property check in a simulation tick of 0ns. For loop finishes execution in a single go.
Sorry, but your answer does not address the question as to why (foo[i] && bar[i]) becomes (foo[10] && bar[10]) after the 1st cycle.
Hello,ben, can I use a automatic varible k=i in loop instead of const’(i)? :rose:
Hi Ben,
your explanation is not very clear can you elaborate more on how loop moves from 0 to 10
