Problem with fork join_any and disable fork
hello, can anyone check why i am getting this type of output while using fork join_any?
code:-
module test;
  int a;
        $display($realtime,,,,,,"before disable");
        repeat(10) begin
          $display($realtime,,,,,,"a = %0d",a++);
    join_any
    disable fork;
    $display($realtime,,,,,,"after disable");
Actual output from questasim:-
0 before disable
0 a = 0
0 a = 1
0 a = 2
0 a = 3
0 a = 4
0 a = 5
0 a = 6
0 a = 7
0 a = 8
0 a = 9
0 after disable
expected output :
0 before disable
0 after disable
You can also run the code:- EDA Playground
Thank you.
Both the threads with in the fork join block doesn’t consume any delay, both of them will be completed at 0 time unit only.
In reply to shanthi:
I also ran this code with VCS it was giving output as expected can you explain why?
But many processes run at zero simulation time, that differentiation has to be done by the tool.
Ex -
thread1 display1
thread2 display2
thread3 display3
join
multiple process in fork join at zero simulation time, but still tool executes them one by one.
output will be: -
display1
display2
display3
In reply to m_v:
This is a race condition. The only guaranteed output is that if printed, “a=0…a=9” must be in order, and that the "after disable must be the last output line. So technically the following is another valid output
0 a = 0
0 a = 1
0 a = 2
0 a = 3
0 before disable
0 a = 4
0 a = 5
0 a = 6
0 after disable
hi Dave, In this all the display statements will be executed in active region and at 0 time so the order of the display is as the user’s order of the display statements so why the #0 before disable is in between and now as per your output the #0 before disable can be any where but before the #0 after disable right?
In reply to m_v:
See sections 4.6 Determinism, 4.7 Nondeterminism, and 4.8 Race conditions in the IEEE 1800-2017 SystemVerilog LRM
In reply to m_v:
module test;
int a;
$display($realtime,“before disable”);
repeat(10)begin
$display($realtime,“a = %0d”,a++);
 join_any
 disable fork;
with this code, you can get the expected output
