I have a DUT memory (reg [7:0]mem[255:0] ) , having a problem in initializing the values with own address( addr 0 → val 0, addr 1 → val 1…addr 255 → val 255)
/// SET SEQUENCE BODY METHOD
virtual task body();
tcam_transaction set_tx;
set_tx = tcam_transaction::type_id::create("set_tx");
for(int i=0; i<256 ;i++) begin
start_item(set_tx);
assert( set_tx.randomize() with { set_tx.set_valid == 1; set_tx.set_addr == i ; set_tx.set_key == i ; } );
finish_item(set_tx);
endclass : set_tcam_sequence
//////drivers run phase
virtual task run_phase(uvm_phase phase );
tcam_transaction tx;
forever begin
@(vif.driver_cb) ;
seq_item_port.get_next_item(tx);
@(vif.driver_cb);
if( vif.driver_mp.rst == 1'b1 )
vif.driver_cb.set_addr <= 0;
vif.driver_cb.set_valid <= 0;
vif.driver_cb.set_key <= 0;
vif.driver_cb.set_xmask <= 0 ;
vif.driver_cb.req_key <= 0 ;
vif.driver_cb.req_valid <= 0 ;
vif.driver_cb.set_addr <= tx. set_addr;
vif.driver_cb.set_valid <= tx. set_valid;
vif.driver_cb.set_key <= tx.set_key;
vif.driver_cb.set_xmask <= tx. set_xmask;
vif.driver_cb.req_key <= tx. req_key;
vif.driver_cb.req_valid <= tx.req_valid;
seq_item_port.item_done();
endclass : tcam_driver
problem arises in dut initialization
mem[0]= 0
mem[0]= 0
mem[1]= 0
mem[1]= 1
mem[2]= 0
mem[2]= 2
mem[3]= 0
mem[3]= 3
mem[4]= 0
mem[4]= 4
mem[254]= 0
mem[254]= 254
mem[255]= 0
mem[255]= 255
// why the values 0 is written at very location
when i am checking in subscriber/////////////////////////////////////////////////////////////////////// EXPECTED line_match 74
UVM_INFO testbench.sv(478) @ 5155000: uvm_test_top.tcam_env_h.tcam_sub [SCORE BOARD] req_valid = 1 req_key = 74 linematch = 0 ///due to wrong /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////initialization
UVM_FATAL testbench.sv(497) @ 5155000: uvm_test_top.tcam_env_h.tcam_sub [tcam_subscriber] Faillllllll
