Printing value of a local variable within a property
Hi
I am trying to print the value of a design signal when the antecedent gets fired of a given assertion:
For e.g
property read_check
logic [7:0] read_addr
@(posedge clk)
(mem_enable && read_enable,read_addr = ) → ##4 $rose(ready)
end proprty
I want to capture and print the value of the read address when the antecedent gets fired and print it when the consequent is evaluated. I tried to do the below but it doesn’t recognize the local variables within a property. I seem to be able to use the variable within the property but is there a way I can print it to a log?
assert property (read_check) begin
$info(“Read address is”,read_addr)
Local variables are not visible outside the property.
you can add a display statement like this…
property read_check
@(posedge clk)
(mem_enable && read_enable,read_addr = rdata, $display(“read_addr=0x%0x”,read_addr)) |-> ##4 $rose(ready)
end proprty
In reply to pavan yala:
Tried the above. It now says its an illegal use of the system task ‘$display’ as a function.
Was also thinking about using $past to print out the antecedent signal but the consequent could fire after different number of clock cycles each time and not sure if I would be able to get the exact value to pass as an input to $past
In reply to tabhay85:
You cant use a local variable in assert statement. You can use $display as shown
property read_check;
logic [7:0] read_addr;
@(posedge clk)
(mem_enable && read_enable,read_addr = rdata, $display("read_addr=0x%0x",read_addr)) |-> ##4 $rose(ready);
This should work.
Please check your syntax errors properly like semicolons, bracket opening and closures. If still your getting errors, Just post it what are the errors and code.
In reply to Anudeep J:
You could also use a function call that may even have side effects, though side effects are generally not recommended. For example:
   int count=0;
   function logic[7:0] do_something(logic [7:0] read_addr);
      $display("read_addr=0x%0x",read_addr);
      count=count+1'b1; // <-- A side effect !!!
    endfunction : do_something
     @(posedge clk)
        (mem_enable && read_enable,read_addr = rdata, do_something(read_addr))
    assert property (read_check);
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
Yes Ben, Function call is also possible.
